Old 11-06-2007, 12:30 PM   #1
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Who says a KA can't rev high?
LOL
Okay so seriously, I need to get my tach working right again. Sometimes it works, sometimes it works but twitches a bit varying around 200rpms off, sometimes it reads idle, and sometimes it ever so slowly climbs to how you see it. The motor in the car is a lower mileage KA, and the previous owner said someting about how the tach is getting the signal from the engine. What should I try, without fishing the gauge cluster out of the dash?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 11-06-2007, 12:43 PM   #2
slow40
slow40's Avatar
slow40 will become famous soon enoughslow40 will become famous soon enoughslow40 will become famous soon enoughslow40 will become famous soon enoughslow40 will become famous soon enough
love the sig man..lol
dropping the cluster isn't that hard though
slow40 is offline   Reply With Quote
Old 11-06-2007, 01:46 PM   #3
LA_phantom_240
Eh... I wanna make sure that there isn't something loose on the motor or something first. And if the tach is bad, what can I do that doesn't require hunting down another SE cluster?
Old 11-06-2007, 01:49 PM   #4
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
Pull out the gauge cluster. Takes 15 mins. Check all wires,tabs, needles.
Worste case, buy a new cluster.?
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 11-06-2007, 02:10 PM   #5
!Zar!
!Zar!'s Avatar
It's most likely the speed sensor.
Check the plug.
Old 11-06-2007, 02:24 PM   #6
LA_phantom_240
Wheres the engine speed sensor?
Old 11-06-2007, 02:29 PM   #7
downshift_sideways
No Limit Soldier.
Should be on the pass side of the transmission.(Under the car)
a harness is ran to it. I think its like a 8-9mm bolt.(not sure)
Old 11-06-2007, 08:42 PM   #8
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
Check the plug.
Not on an S14 my friend. I don't even have a speed sensor and my tach works. Check the CAS on the top of the transmission right behind the engine. It measures the flywheel speed to show your RPM
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 11-07-2007, 12:05 AM   #9
LA_phantom_240
How hard is it to get to?
Old 11-07-2007, 12:53 AM   #10
Skullavera
Skullavera's Avatar
Skullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfection
Send a message via AIM to Skullavera
Oh shit! How the hell does my rpm gauge work? I don't have that on my tranny! Lol.
On an S14 the RPM signal comes from the distributor (internal coil). Check your distributor plug and look for any pins that may not be making contact. I believe the problem itself may lie in that or your cluster. If you have a spare distributor, just install it and see if that's it. If it's not then it's the cluster. If that doesn't work then the problem must lie in the wiring itself. Download the FSM and check the wiring. That's what I'd do.
Also, the CPS (Crankshaft Position Sensor) does not read RPM. This was taken directly from the FSM:
"The crankshaft position sensor (OBD) is located on the transmission housing facing the gear teeth (cogs) of the flywheel (driveplate). It detects the fluctuation of the engine revolution. The sensor consists of a permanent magnet, cor and coil. When the engine is running, the gap between the sensor and the gear teeth (cogs) will periodically change. Permeability near the sensor also changes. Due to the permeability change, the magnetic flux near the core is changed. Therefore, the voltage signal generated in the coil is changed. The ECM receives the voltage signal and detects the fluctuation of the engine revolution. The sensor is not directly used to control the engine system. it is used only for the on-board diagnosis of misfire."
Reviews/Feedback!
Skullavera is offline   Reply With Quote
Old 11-07-2007, 12:56 AM   #11
ixfxi
Guest
Posts: n/a
i think you threw a rod
is your check engine light on? did you pop your hood and check to see if your engine is still there?
haha sorry man, i'm still recovering from the honda/burbank 240 meet i accidentally went to tonight
Old 11-07-2007, 01:18 AM   #12
Skullavera
Skullavera's Avatar
Lmfao!!!!!^^^^
Reviews/Feedback!
Old 11-07-2007, 07:29 AM   #13
LA_phantom_240
I have NO spare s14 parts layin around. I have about enough s13 parts to build one, sans body.
Old 11-07-2007, 09:34 PM   #14
LA_phantom_240
Yeah, my tach is bad. It broke today. It is stuck pegged out. Time for an aftermarket unit.
Old 11-07-2007, 09:56 PM   #15
Skullavera
Skullavera's Avatar
Aftermarket unit? Please don't tell me an APC 50" Widescreen Super Tuner tach for your dash....
Reviews/Feedback!
Old 11-07-2007, 10:02 PM   #16
johngriff
johngriff's Avatar
just find another tach @ the junk yard, remove it from the gauge cluster, replace.
[email protected]
Old 11-08-2007, 02:23 AM   #17
LA_phantom_240
Actually, I was thinking of getting a small sunpro... like 3". Something discrete, that I can put in front of the factory tach without much blockage.
Oh and about finding a junkyard tach... yeah, there are no s14s in junkyards within like 100 miles of me.
Old 11-08-2007, 02:30 AM   #18
Skullavera
Skullavera's Avatar
Just source a cluster here on zilvia. They usually run about 40-60 bucks. This guy is parting out his S14. Maybe he can help you out.
http://www.zilvia.net/f/showthread.php?t=163743
Reviews/Feedback!
