Old 11-08-2007, 11:25 AM   #1
JTunedMotorsports
Zilvia.net GB Vendor
Trader Rating: (65)
JTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enough
Feedback Score: 65 reviews
Send a message via AIM to JTunedMotorsports
what Earls fitting to convert s13 circuit sports coolant line to work on s14waterneck
Ok since my water tubes behind the intake mani on my s13 sr20det are rusted I was gonna cutoff the pipes and bypass that section..Now I would like to use a s14 water neck and convert my one circiut sports coolant feed line to work onthe s14 water neck.. So what earls fitting(S) will i need to make this happen, so I dont have to get another set of lines...I am running the stock t25 turbo by the way.
thanks
Jim
JTunedMotorsports is offline   Reply With Quote
Old 11-08-2007, 11:37 AM   #2
luisgonz
luisgonz's Avatar
luisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfection
Send a message via AIM to luisgonz
well the s14 just has a -6 straight fitting . Are you using the 90 fitting on what side of the turbo, The reason Im asking because you might need to get a longer hose. If i was you I would use a 45 on the water neck housing it well look so much better.
luisgonz is offline   Reply With Quote
Old 11-08-2007, 12:45 PM   #3
JTunedMotorsports
Trader Rating: (65)
yes i have the 90 on the turbo. do i really need a bigger hose..i will prob get the pieces for another 90 and then get the water neck and just do it after the motor is in.
Old 11-08-2007, 06:35 PM   #4
luisgonz
luisgonz's Avatar
You may want to test fit before you put it in. But put a 45 on the water housing
It all ready at a 45 degree angle so your just going to make it a 90. Let me find some pics of it on my mock up motor I use to mock crap on.LOL
Old 11-08-2007, 07:02 PM   #5
JTunedMotorsports
Trader Rating: (65)
what i want to do is use my s13 bottom mount circuit sport coolant braded feed line which faces the brake boost, and use that hose it its long enough to run it to the s14 water neck im gonna order...i just need to get the red and blue earls 90 and then the stright fitting that threads and im good..
