Old 11-20-2002, 12:33 PM   #1
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
What's up guys, i've been having a problem as of late.  I know that i have ABS because the light on my dash lights up when i start the car also have Hicas and a lsd. btw i have a 91.
But anyway the other day i was driving and i had to slam on my breaks to avoid hitting someone who cut me off and my car's tires locked up and i slid a few feet. This never happened before is there something wrong with my antilock brakes?  ABS makes it so the car does not lock up right?  Can anyone give me some ideas why it does this.
Thanks in advanced
hookedup240 is offline   Reply With Quote
Old 11-20-2002, 12:58 PM   #2
Dousan_PG
Dousan_PG's Avatar
what type of tires do you have? your stopping power is in two places:
brakes
tires
good tires will make excellent braking as well. its your tires that stick, your brakes can be BREMBO but if your running crap tires, your still going to have crap braking
Aaron
Pink GodziRa
Old 11-20-2002, 01:00 PM   #3
AKADriver
AKADriver's Avatar
how fast were you moving before braking?  ABS won't engage below a certain speed.
It's also not infallible.  Did you hear the ABS pump or feel it through the pedal?
Old 11-20-2002, 01:08 PM   #4
hookedup240
I have Falken Aziens (sp?) tires 215/35/18, but i did not feel the abs pump through the pedal.
I was going about 50-55 maybe
Old 11-20-2002, 01:10 PM   #5
Dousan_PG
Dousan_PG's Avatar
well your tires are good DEPENDING on their tred
also! what about the road conditions? how was the surface you were on? azenis suck in rain for the most part, and if the surface was slick or possibly too smooth the tires coud/may/would slide as well.
Aaron
Pink GodziRa
Old 11-20-2002, 03:23 PM   #6
hookedup240
Well they have good tread, and it wasn't wet out either i don't know what kind of road it was smooth or something guess its just one of those things
Old 11-20-2002, 06:39 PM   #7
kandyflip445
kandyflip445's Avatar
Does your ABS light STAY on when your car is running? Or does it just go out after you start it? It could be a number of things with ABS. If the light does stay on then get the DTC(Diagnostic Trouble Code) from the ECU. If it doesn't then your best bet would be take it to a shop. They would have to run diagnostics on it. I could probably do it for you but you probably don't live in Kansas <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hmmm.gif" border="0" valign="absmiddle" alt=':hmmm:'> . Good luck.
My 240 vBgarage
Old 11-20-2002, 08:24 PM   #8
HKrpS13
HKrpS13 is an unknown quantity at this point
Send a message via AIM to HKrpS13
I think you need to bleed the ABS
HKrpS13 is offline   Reply With Quote
