Old 11-09-2007, 01:31 PM   #1
thewhiteknight
thewhiteknight's Avatar
thewhiteknight has made poor choicesthewhiteknight has made poor choicesthewhiteknight has made poor choicesthewhiteknight has made poor choicesthewhiteknight has made poor choicesthewhiteknight has made poor choices
bad things happened... need a little help
alright so i was screwin around and racing some car... about 5-10 minutes after that my cars thermostat reads to the high heavens. i pulled over, filled the radiator back up, and went home for the night. the next day i started it up and heres what happens;
the thermostat reads hot really fast after starting, when i turn the heat on it comes out cold.
i searched around but i didnt find any match of these two symptoms. any opinions are appreciated
thewhiteknight is offline   Reply With Quote
Old 11-09-2007, 01:32 PM   #2
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Try replacing your thermostat.
Alex
e1_griego is online now   Reply With Quote
Old 11-09-2007, 01:34 PM   #3
thewhiteknight
what about the whole cold heat thing?
Old 11-09-2007, 01:35 PM   #4
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
you might have a bad tstat, an air bubble in your system, your radiator might be plugged, or you might have blown your hg.
most likely not the hg but you might want to look into bleeding your system first. make sure your cts is working ( the single wire one)
supreme_1 is offline   Reply With Quote
Old 11-09-2007, 01:42 PM   #5
thewhiteknight
are there any compatible cts's that i could find easier than an sr20?
Old 11-09-2007, 01:50 PM   #6
supreme_1
i am not sure, but maybe a fwd sr20 maybe a ka? try and let your car heat up and then wiggle it around. but i dont think that it is your problem. may be but probably not.try and bleed it.
my s10 that i have with a bhg idles at perfect temp, but when i drive it it heats up quick, and then when i idle again it drops in temp real quick.
Old 11-09-2007, 01:54 PM   #7
thewhiteknight
what about a blown turbo? i was thinking thats what it was at first...
Old 11-09-2007, 01:56 PM   #8
supreme_1
i havent owned a turbo charged car, so sorry to say but i cant help you.
from what i kinda read is that if you blow a seal then you will blow smoke.try and do a search
Old 11-09-2007, 02:05 PM   #9
89dc240
89dc240 will become famous soon enough89dc240 will become famous soon enough89dc240 will become famous soon enough89dc240 will become famous soon enough89dc240 will become famous soon enough
Kinda makes it sound like you knew your rad was leaking. Why race somebody if your car is fucked up?
89dc240 is offline   Reply With Quote
Old 11-09-2007, 02:15 PM   #10
used240sxparts
Guest
Posts: n/a
Ok, first here are some things to try:
1. Make sure your fans are working (most likely not your problem)
2. Bleed your coolent system
3. Check to see if your rad. cap is bad
4. See if your thermostat opens up, if you need a new one for the sr get the nismo one from justin at west covina.
thats all i can think of.
ps i doubt your turbo is blown
Old 11-09-2007, 02:33 PM   #11
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
Haha thats the way to advertise
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 11-09-2007, 02:57 PM   #12
WISH ONE
squeeze the upper radiator hose and see if you feel it pulsating or bubbling. most likely thermostat or air in the system.. dont know tho.. maybe your heater core is bad
Old 11-09-2007, 07:41 PM   #13
supreme_1
do you have pressure in your system?
i would say to start with bleeding your coolant since its cheap/free to do yourself. if you dont know how search " bleeding coolant"
gl
Old 11-11-2007, 04:30 AM   #14
thewhiteknight
whoa
ok so last night i was starting to bleed my coolant when i look under my only to find that it is dumping out from somewhere near my bellhousing. it was coming pretty heavily. any ideas whhat could be shooting coolant out like that? it was dark so i didnt have a chance to take a look at it....
Old 11-11-2007, 09:10 AM   #15
orion::S14
orion::S14's Avatar
^^^ Heater core hose...goes from the block, into the heater core under your dash.
If they leak, and/or come off...coolant dumps onto your bellhousing.
- Brian
www.KA24DEvelopment.com
Old 11-11-2007, 09:23 AM   #16
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
Bingo. Heater hoses in the back of the motor.
SDS13COUPE is offline   Reply With Quote
Old 11-11-2007, 09:40 AM   #17
thewhiteknight
great
thanks alot, is the hose within reach from underneath the car without removing anything? also how will i identify it?
Old 11-11-2007, 12:40 PM   #18
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
they are on the passenger side next to the head
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
