Old 11-20-2007, 05:15 AM   #1
Harinjo
Harinjo is an unknown quantity at this point
Which Master Brake cylinder should I take?
for my S13? (S12,S13,S14 or Z32)
front brakes: Wilwood SL4 13" 4pot
rear brake: stock
Harinjo is offline   Reply With Quote
Old 11-20-2007, 05:34 AM   #2
Firestorm
Firestorm's Avatar
Firestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond repute
Send a message via ICQ to Firestorm
hey hary, you could've asked this question in the german SX-board
if i were you, i would go with a Z32 BMC, since you said your front calipers are compact in size i think the Z32 one will be just fine
maybe you should use an adjusting valve for the rear brakes, just in case if braking force on the rear is too much, since the Z32 BMC is designed for 2-pot calipers for the rear brakes.
Firestorm is offline   Reply With Quote
Old 11-20-2007, 05:44 AM   #3
Harinjo
Sounds plausible, but I thoght somebody here should have experience with the SL4 brake system.
Old 11-20-2007, 06:02 AM   #4
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
hey, i have a *new s13 brake master for sale, its the ABS model
i think its the same size as a z32 master. lemme know, ill sell it dirt cheep
Chrischeezer is offline   Reply With Quote
Old 11-20-2007, 07:50 AM   #5
Harinjo
Is there any difference between Z32 NA and Z32 TT BMC?
Old 11-20-2007, 07:57 AM   #6
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
^-- i doubt it as they both had 4 pot brakes up front and 2 pot in the rear.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 11-20-2007, 07:59 AM   #7
Harinjo
But the discs on front are thicker @Z32 TT
Old 11-20-2007, 08:44 AM   #8
Firestorm
Firestorm's Avatar
disc size doesnt really matter, whats more important is the pot size and overall caliper size.
oh yeah, what i just remembered, the EUDM S14 came with 4-pot up front and 1-piston calipers in the rear, so the S14 BMC may be better for your setup. i don't know if the size is much different from Z32 BMCs but brake bias should be better if you plan on running stock calipers on the rear.
Old 11-20-2007, 09:09 AM   #9
projectRDM
projectRDM's Avatar
Not even close. 7/8" and 1" aren't the same size.
FORMERLY R240NA
