FMIC...battery issue
im looking into putting my battery in the rear or just getting a smaller one..what do you guys recomend?? i think just getting a smaller one would be easier...but then what size battery would i need? and out of what car should i get the batter out of ? if you guys know help me out....thanks
![]() Join Date: May 2006
oddessy p680 i think
works well try other dry cells
If you are planning on having a system (Audio) in your car, don't get a smaller battery. I mean it will work, but i wouldn't recommend it. I just relocated my battery to my trunk for under $60. If you need help, just PM me!
what he said for me i dont have a stereo system or anything whyause i'm getting sick of thieves jacking my cd deck.
I installed my FMIC this past weekend, and decided to just relocate it. It took alittle more time but it cleans up the engine bay and is cheaper than buying a small dry cell or a miata battery. Cost me about $50ish to relocate whereas buying a smaller battery was $75-100. Also saves u the trouble of running wiring through your car for a sub.
#8 | |
Go to walmart in the automotive section where they sell batteries and pick up a battery box and then get a battery tiedown from a autoparts store. Box is like 10bucks and tie down is about the same.
#10 | |
![]() Join Date: Feb 2007
edit :whoooops. sry, just sold it, good luck Last edited by eli_eli; 12-06-2007 at 01:18 AM.. |
#15 |
Man w/ CTSV & a Car Seat
Miata or civic batthery should fit. The only thing that sucks about relocating it to the trunk is that if you go to track where they are really strict, they will require you to have a kill switch installed for the battery.
#16 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
or you could just route your intercooler piping around the tension rod brackets, thats what i did for my ka-t
Slip Gypsies Blog Quote:
#17 |
My battery is re-located to the trunk and is easier access. I run a battery charger between rounds to cool my engine at the track. With it in the trunk Im able to put a kill switch on it and also terminals so I dont even have to raise the trunk or hood. Its alot nicer IMOP!!!!
#18 |
braill auto with out a doubt also there is a thread on this you know hear i'll make it easy for you and i'll give you first hand experience it weighs 11.5 lbs small as a motorcycle batter and starts great in the cold weather too best part its been race proven!! any way here's the thread read my post explains better
http://www.zilvia.net/f/showthread.p...28#post1432928 oh ps here is the link to brail auto i beleve that they now have a even lighter one http://www.brailleauto.com/productca...16&idproduct=8 or the one i have http://www.brailleauto.com/productca...17&idproduct=1 works even with a 500watt system ![]() |
#19 |
I just relocated...the common thought is that most small batteries do not hold up as well. Using your STANDARD, note the caps, sized battery is always recommended for long-term use.
97 240sx se |
#20 |
![]() Join Date: Mar 2002
I just ran a civic battery like previously stated. I had a civic at the time so it was a "no-brainer"
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP |
#21 |
![]() Join Date: Jun 2007
You can buy good quality small batterys just most people cheap out and see problems. Any good new smaller battery should be better then your stock or even a low priced stock sized one. Relocating sucks IMO unless you drag race, that weight is needed in the front of the car.
#26 |
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() Feedback Score: 1 reviews
I am a honda guy....sorry
http://www.jhpusa.com/catalog/produc...e427547b007b6d I had that battery in my DD accord for nearly a year...worked great and 115$ for an 11lb battery ![]() need to get the terminal kit also so under 150$ shipped
#27 |
If you want to run a battery under the hood, you can get a MAZDA MIATA battery or go with the WESCO battery. I'm running a WESCO battery and it fits perfectly. You can also use a honda civic bracket to hold down the battery.
KEEPIN IT REAL! ![]() |
#28 |
remember that batteries contain materials that you don't necessarily want sitting close to you in case of an accident.
I picked up a relocation kit from Summit Racing...though I guess their price went up on their Summit brand kits. (paid ~$90 shipped)
97 240sx se |
