Old 12-06-2007, 05:38 PM   #31
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
Originally Posted by punxva View Post
or you could just route your intercooler piping around the tension rod brackets, thats what i did for my ka-t
This method > all other methods.
I hate having a tiny battery! Left my car off for 1 week and it didn't have enough juice to start.
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 12-07-2007, 12:28 AM   #32
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Miata battery from Vatozone.
Cheap. It' fits perfectly. It workds.
No complaints.
HalveBlue is offline   Reply With Quote
Old 12-07-2007, 12:39 AM   #33
Triadz101
Triadz101 has made poor choicesTriadz101 has made poor choicesTriadz101 has made poor choicesTriadz101 has made poor choicesTriadz101 has made poor choicesTriadz101 has made poor choicesTriadz101 has made poor choices
I took some nice pics (with my cell phone, but it's a nice 3.2MP!) only to realize that my laptop is dead and my desktop doesn't have the application for me to transfer it over
Anyways, I have a greddy FMIC (VSPL) and I relocated mine to the trunk. Which is what your better off doing. I did it myself, it was probably the easiest thing I've ever done in my life. And for the battery tray in the trunk, I drilled 4 holes (where the nuts would enter) in the trunk, placed the nut appropriately, hammererd it in lightly and then welded it in place so it won't move or fall out. Then I placed my battery tray over it and put in some bolts so I can easily remove the battery tray if I needed to and it looks cleaner that way too. Then obviously the kit included a strap for the battery which hooks onto the tray itself. On the S14's, the trunk has a bolt that connects to the rear subframe I believe, not too sure, but it's in a hole and I put my ground to that, bent the metal a bit to make sure the ground is SOLID, but it's covered up by the carpet and over winter I will be attempting to make some fiberglass cover around the battery area, with an open\close lid for easy accessability to the battery.
and i have a small 10" sub with a small 310 watt amp and obviously i went with an OEM Nissan battery (regular size, since it is in the trunk, don't gotta worry about size anymore) and it goes good, with the smaller battery, I noticed it wasn't getting enough juice in the cold and would die quickly...
Anyways, hope this helps you out a bit, but I know i went kind of off topic, but too lazy to edit it! hehe....
Triadz101 is offline   Reply With Quote
Old 12-07-2007, 01:00 AM   #34
xplicit240
xplicit240's Avatar
xplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nice
Send a message via AIM to xplicit240
im using the westco slim battery. hasnt failed me yet. and can still fit snug beside the pipe. =)
xplicit240 is offline   Reply With Quote
Old 12-07-2007, 02:42 AM   #35
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
miata battery from autozone!!! has like a 7yr warranty. left the car for 3weeks, jumped in, started right up. fits really well, almost perfect i'd say. the westco one is another great alternative since its made for the miata but with a higher CCA.
eek is offline   Reply With Quote
Old 12-07-2007, 05:18 AM   #36
g6civcx
g6civcx's Avatar
Optima yellow top relocated to the rear seat of a hatch.
Make sure you use a dry cell and have a vent tube.
Old 12-07-2007, 06:24 AM   #37
xamraci
xamraci will become famous soon enoughxamraci will become famous soon enoughxamraci will become famous soon enoughxamraci will become famous soon enough
since I just realized that you live in "god its -10 degrees today country..."
Certainly consider a battery with high CCA because if you dont...you will probably be screwed...I think oddysey offers a 900-950CCA battery thats still relatively small
xamraci is offline   Reply With Quote
Old 12-07-2007, 10:20 AM   #38
Rob's S14
Rob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfection
Send a message via AIM to Rob's S14
my buddy runs an odyssey and he's had no problems. he just replaced his old one which he had for about 3-4 years. weather is much warmer out here though, so listen to xamraci.
Rob's S14 is offline   Reply With Quote
Old 12-07-2007, 10:13 PM   #39
eulalia
eulalia's Avatar
eulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfection
Send a message via AIM to eulalia
i just have a quick question, i have a small system in my car 12inch sub, amp the works, and i just got my fmic, so what do i do?
the only problem about moving the battery to the back is because i have a custom box, its possible but its going to be a hassle
will it be fine if i get a miata battery, or a buddyclub small battery? or should i just deal with it and put the battery in the back?
eulalia is offline   Reply With Quote
Old 12-07-2007, 10:54 PM   #40
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
westco miata battery fTW
will hold a system too
475CCA!
importdude is offline   Reply With Quote
Old 12-07-2007, 11:10 PM   #41
xamraci
to the OP and anyone else who lives in cold ass areas of the country
http://store.summitracing.com/egnsea...6&NeXID=110946
MY NRG-CELL battery was 120CCAs and weighed 11lbs...dunno if thats gonna work for you guys up north..but it was nice
Old 12-08-2007, 12:45 AM   #42
jakethesnake
jakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymore
thanks everyone!! i got my battery and im all set...
jakethesnake is offline   Reply With Quote
Old 12-08-2007, 03:25 AM   #43
!Zar!
!Zar!'s Avatar
475CCA!
Too bad that isn't continuous.
Old 02-12-2008, 08:37 PM   #44
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
Has anyone tried this battery?????
http://www.good-win-racing.com/Mazda...t/42-1004.html
hotlavaflow is offline   Reply With Quote
Old 02-12-2008, 08:48 PM   #45
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Man up and relocate it. Those little batteries always end up having problems.
blu808 is offline   Reply With Quote
Old 02-12-2008, 09:05 PM   #46
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Options are small battery or relocated battery.
I did the former:
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 02-12-2008, 10:13 PM   #47
240cracker
240cracker's Avatar
Trader Rating: (22)
240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to 240cracker
I just used a miata BAT.
I had my old s14 relocated b4. Even since then it has electrical problems
240cracker is offline   Reply With Quote
Old 02-12-2008, 10:27 PM   #48
180sx_Drifter
180sx_Drifter's Avatar
180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection
like what everyone said before me if you plan on having a system relocate. if not then you can get a 1995 miata mx5 battery. Thats what i have in my car and runs fine. if you have the money get an oddessey battery.
180sx_Drifter is offline   Reply With Quote
Old 02-12-2008, 10:39 PM   #49
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
yeah the little batteries seem to lose cells, when all else fails i know a lot of guys using tractor batteries. or just relocate it, but if you want to run the car at the track youre going to need a nhra approved battery box, if you have a hatch back its gotta be a closed top box, and if its a coupe you dont need the top.
landins13 is offline   Reply With Quote
Old 02-12-2008, 11:59 PM   #50
hotlavaflow
Unless your interior is stripped. If there isn't a divider between the driver and battery you need a cover.
Old 02-13-2008, 12:01 AM   #51
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
What he said. Not to mention that re-locating it takes 2 hrs.and $50.
mRclARK1 is offline   Reply With Quote
