![]() Join Date: Aug 2001
I was wondering how much a used vlsd from a wrecking yard usually costs. I was quoted $575 shipped for an Infiniti J30 VLSD and I don't know. What do you guys think? Thanx
![]() Join Date: May 2001
Im pulling mine out of my crashed '95 SE hopefully on Tuesday. I think that i'll be putting it up on ebay since Ive had a few people requesting it.
Ill be sure to post the link here for those interested. Greg ex-'95 SE |
AutoX Junkie
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from burgy240 on 9:44 pm on Oct. 29, 2001
V= Viscious LSD I don't know why it's called that though. </td></tr></table><span id='postcolor'> Just FYI A viscous limited slip uses a thick (silicon-based?) fluid that gets thicker with heat. This fluid acts as a clutch between the plates of the two shafts. If one shaft begins to spin significantly faster than the other, the viscous fluid will thicken and 'lock' the other shaft so power is more evenly distributed and wheelspin is minimized. more info BTW, $575 sounds pretty steep...I say keep looking. |
Thanx... I found another in Canada for 350 but its gonna cost like 100 bucks to ship it. So I guess the price is still pretty high. Its my only option, I guess, Rapid Shitty(City), SD isn't going to have any soon.
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from rabbit23 on 9:55 am on Oct. 30, 2001
not sure if this is a dumb question or not, but do you have to switch to 5 lug to swap the lsd? </td></tr></table><span id='postcolor'> Nope...at least not as far as I know. You only have to swap the differential. Anyone know how much labor this is? |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from ditosx on 11<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>0 am on Nov. 5, 2001
Found another VLSD off of an Infiniti M30... anyone know if it will bolt right in??? No hassle, no fuss?? </td></tr></table><span id='postcolor'> You might have to shorten the driveshaft by one inch but I'm not sure. Other than that, you are good to go with an M30 diff. |
Hey boy's and girl's,
<a href="www.pdm-racing.com" target='_blank'>www.pdm-racing.com</a> is selling a lsd for 400 plush shipping. He only has one so check it out. I wouldn't tell you about this but I can't afford it right now, bills and Christmas are killing me. |
#15 |
Nope, its an option on the se's. Theres a good web page with the info fro determining if it has an LSD from the model # thta sombody posted before. Donr remember it offhand though.
The labor shouldnt be much I wouldnt think, but i would just reccomend doin it yourself. Its really easy. As long as the driveshaft and output shafts are the same, which the should be if you have an s14 w/ abs, then its just 6 bolts on each output shaft, 4 on the driveshaft, and 4 to mount it. Greg |
#16 |
Pearl White Mike
go over to www.240sx.org and in th installs section theres a VLSD install, i thas alot of good info about what LSD's are good for the 240, and how to install them, and which ones will go right in, or need modifications
