Old 12-10-2007, 01:53 PM   #1
Bigballin
Bigballin's Avatar
Bigballin is an unknown quantity at this point
s14 Rear Tires dont last more than 100 miles
actually the rear tires last for about 300 milles then its completly bald. this started happening after i completed my 5 Lug conv. i replaced the whole rear knuckle for both sides (if that helps any). im pretty sure i know what the problem is but i would like some advice or info before i proceed to fix it.
thanks
Bigballin is offline   Reply With Quote
Old 12-10-2007, 01:57 PM   #2
240sxrb25
240sxrb25 is an unknown quantity at this point
sounds like you have a heavy foot
240sxrb25 is offline   Reply With Quote
Old 12-10-2007, 01:58 PM   #3
drifting.8
drifting.8's Avatar
Location: What's heavier a pound of iron or a pound of feathers??
drifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud of
Send a message via AIM to drifting.8
um.... dont mean to be an ass but the red square lets me know ur a noob.. as am i.. but do u have a welded diff? changin to 5 lug should't be the reason your tires are goin bald.. correct me if im wrong.
RB 25DET NiZTECH BUILT
drifting.8 is offline   Reply With Quote
Old 12-10-2007, 01:58 PM   #4
wonkuuzenki
wonkuuzenki's Avatar
wonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-known
Check the toe in or out of the wheels, or for excessive amout's of camber.
do you have RUCA's? or any onther non-stock rear suspension parts?
Or you could try to lay off the gas a little bit
Is it only the inner portion of the tire or the complete thing?
Function. Form.
Step Up Drift Club/Upper Limit!
wonkuuzenki is offline   Reply With Quote
Old 12-10-2007, 02:02 PM   #5
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
get an alignment.
driftyour40 is offline   Reply With Quote
Old 12-10-2007, 02:24 PM   #6
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
post pics show us how it looks like
S13Boosts is offline   Reply With Quote
Old 12-10-2007, 02:50 PM   #7
TheSquidd
TheSquidd's Avatar
Hahahah you're retarded.
I have welded diff, and my tires last for thousands of miles.
Obviously this is a toe in/out problem, that's the only logical explanation of this kind of wear (aside from drifting). Not even camber should wear this much tire that fast.
I suggest you see an alignment shop ASAP
TheSquidd is offline   Reply With Quote
Old 12-10-2007, 02:53 PM   #8
LongGrain
LongGrain's Avatar
you have a toe problem
get an alignment.
LongGrain is offline   Reply With Quote
Old 12-10-2007, 03:08 PM   #9
Bigballin
Bigballin's Avatar
i figured it would be an alignment problem. just wanted to make sure. thanks for the replies!
Old 12-10-2007, 03:17 PM   #10
wonkuuzenki
No problem.
you could even drive up to NM and i would gladly do it for you.
Oh wait, you wouldn't make it here, haha
Function. Form.
Old 12-10-2007, 03:18 PM   #11
wannabe_drifter
wannabe_drifter's Avatar
wannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to behold
What the others said : alignment !
http://i123.photobucket.com/albums/o308/two40/Mine/CoupeSte-Croix.jpg
wannabe_drifter is offline   Reply With Quote
Old 12-10-2007, 04:29 PM   #12
BoostinGST
BoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant future
toe problem... if it were fwd it could be the wheel bearings but the fact that the rear wheels control how fast the car is moving tells you its the toe... get an alignment as the others said... and lighten up on the gas pedal
www.DecalsStore.com custom decals... buy a premie account and save money from me
BoostinGST is offline   Reply With Quote
Old 12-10-2007, 04:49 PM   #13
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
go fix you BIG toe
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 12-10-2007, 05:39 PM   #14
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
Alignment problems probably caused from having stuff loose while doing your 5-lug swap.
KA-T_240 is offline   Reply With Quote
Old 12-10-2007, 05:58 PM   #15
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
i had the same issue. My brand new BFG's were gone in about 3 months and then my new falkens were gone in 3 months. So when i spent the bucks on nice tires for my new rims i went and got an alignment and sure enough it was way off. Gave them my own specs and now my new tires dont even show any sign of wear with about 1000 miles on um. Oh yeah i have a welded diff to.
drifter808 is offline   Reply With Quote
Old 12-10-2007, 06:04 PM   #16
Irukandji
Alignment.
Welded diff won't do shit. I don't know why people always bitch about it. I drove with a welded diff for 2 years and I only had to change rear tires ONCE for my daily wheels (track was a different story)
Old 12-10-2007, 06:23 PM   #17
Sonic Motor
www.SonicMotor.com
Sonic Motor's Avatar
Trader Rating: (113)
Sonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfection
Feedback Score: 113 reviews
Send a message via AIM to Sonic Motor
I too, believe that its your Toe.
welded diff doesnt waste tires that fast. I use to rock welded
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK )
Sonic Motor is offline   Reply With Quote
Old 12-10-2007, 06:37 PM   #18
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
I have welded diff, and my tires last for dozens of oil changes, because I don't drift much...
Old 12-10-2007, 08:31 PM   #19
drifting.8
drifting.8's Avatar
its these kind of replies that show humilty on my part... thats why i put correct me if im wrong.. i did't ask u to be a dick. Ive obviously never had toe in/out problems on my car
Old 12-10-2007, 08:57 PM   #20
TheSquidd
TheSquidd's Avatar
It's the only way I know how to be!!!
