Old 12-10-2007, 12:05 AM   #1
pignose4life
pignose4life is just really nicepignose4life is just really nicepignose4life is just really nicepignose4life is just really nicepignose4life is just really nicepignose4life is just really nicepignose4life is just really nicepignose4life is just really nicepignose4life is just really nice
Send a message via AIM to pignose4life
overheating issues
ok so my sohc has taken a turn for the worst, ill start out by saying i have a 89 240sx with the stock ka24e 200k+ miles. anyways my water pump went out i replaced it, to find out that my radiator is also cracked. i replace my radiator get my car up and running. shortly after replacing the radiator i noticed lots of white smoke coming out of my exhaust when warming up for the first couple of minutes. i thought its just steam and the cold weather so i let it warm up, no water leaking from under so i go around the block for a test drive. right from the start i noticed my car running like shit, rpm's all over the place when idling, and real rough on low rpm's. so driving no more than 3 or 4 blocks my temp is about 2 lines away from the bold H lines. i get home real quick to check it out and i notice that a bit of oil has leaked from the left side of the valve cover. so i try and start up again and its not starting, its at the verge of starting but it doesn't. i let it sit for a bit, and it starts up with the white smoke again, so i let it idle for a good 15 minutes the white smoke goes away, and its at the normal temp about the second line. i go around the block again and the temp goes up to the same H point as before. can you guys please help me out.
pignose4life is offline   Reply With Quote
Old 12-10-2007, 12:26 AM   #2
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
white smoke= burning coolant...not a leak outside the engine...maybe you have a leaking headgasket or cracked water passage. your gonna want to do a compression test and a maybe leakdown if you can access the equipment needed.
njd07 is offline   Reply With Quote
Old 12-10-2007, 12:32 AM   #3
pignose4life
well im using water for the time being in case of leak i dont want to waste money. anyways ill do a compression test tomorrow and report back with update.
Old 12-10-2007, 01:12 AM   #4
dops13
dops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nice
The white smoke = bad headgasket. Do you mean just hot air that looks white? Im think it's just the cold weather. I think your problem is you need to bleed out the air out of your cooling system at the moment. Make sure you did that right.
dops13 is offline   Reply With Quote
Old 12-10-2007, 01:36 AM   #5
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Headgasket.
Your broken waterpump and cracked radiator probably let the engine overheat leading to a bad headgasket.
Good Luck!
HalveBlue is offline   Reply With Quote
Old 12-10-2007, 01:37 PM   #6
wonkuuzenki
wonkuuzenki's Avatar
wonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-known
blown headgasket...
wait you don't own an MA70?!?!
Function. Form.
Step Up Drift Club/Upper Limit!
wonkuuzenki is offline   Reply With Quote
Old 12-10-2007, 02:25 PM   #7
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
yup headgasket or check ur water pump
S13Boosts is offline   Reply With Quote
Old 12-10-2007, 02:41 PM   #8
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
i have the same problem rite now too..can it be thermostat?
Slammed Assassin is offline   Reply With Quote
Old 12-10-2007, 04:08 PM   #9
pignose4life
i was thinking it was the head gasket too but ill know for sure when i get that compression test, waiting for my friend on it =[
thanks for the help guys and no i dont have a supra
Old 12-10-2007, 04:21 PM   #10
wonkuuzenki
it was a JOKE.
Function. Form.
Old 12-10-2007, 04:35 PM   #11
rlpinoy
rlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choices
when you changed your water pump your should of changed your thermostat as well. sounds like it could be either head gasket or thermostat no opening up.
FS Exhaust, Q45 ignitors, & MORE!
rlpinoy is offline   Reply With Quote
