![]() if someone could please provide me with head bolt torque specs for both s14 ka and s14 sr i would appreciate it. i do not have FSMS on my new pc yet, sorry!
thanks in advance -devon
WTB-NARDI wheel & NRG 2.8 QR |
![]() Join Date: Sep 2006
SR with ARP's at 70 with molly lube, if using regular motor oil torque it to 80.
-Jon
momentumgt.com - "building blocks of speed" |
![]() Join Date: Oct 2003
S14 SR (page 63):
http://static.carvolution.org/files/S14_SR20DET_FSM.pdf S14 KA (page 19): http://static.carvolution.org/files/...X%20FSM/EM.PDF |
according to the fsm's, it looks like both (sr and ka) are to be torqued at no more than 60foot/lbs. am i reading this wrong? i appreciate your help thus far guys!
#5 | |
tighten to 30 tighten to 60 loosen tighten to 30 tighten to 60 *(thanks russ) DONE check those pages for the exact numbers but those should be close |
With my headgasket and arp headstuds, I torqued to 80 ft lbs on my SR. Many others torque to that value as well. I would not go less than 70 ft lbs for an SR.
s13 sr20det |
#7 | |
![]() Join Date: Dec 2002
29ft-lbs 59ft-lbs loosen 29ft-lbs 59ft-lbs The first two steps stretch the bolt to spec.
we are talking a new oem head gasket, new head studs on an sr.
just to be clear. like i said in a previous post, it looks like 60 ft lbs is what they want. you guys that are saying 70-80, or i will blow headgaskets, what is your reasoning?
My bad, on the next page in the sr fsm after tightening to 30 it calls for turning all the bolts 90* with an angle wrench and then turning them all again another 90*, and looking at the "elastic" image next to the studs it looks like its supposed to be just slightly more than 60 in the end. With new studs you might want to do the last part in 2 steps as the fsm calls for.
#10 | |
I even think the stock headbolts are greater than 60 ft lbs. I don't feel like looking it up right now, but I would torque them to atleast 70 ft lbs, or better yet, follow the fsm. The fsm is the best way to do it right. The reason you want more torque is so your headgasket does not leak. I fear putting just 60 ft lbs will cause a slow leak and then you will have to replace it sooner than later.
s13 sr20det |
