Old 12-15-2007, 01:23 AM   #1
thedecapitator
thedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choices
sr20det running like shittttt!
hi i am having a problem with my sr20det motor it sounds like a SUBARU STI .. like its misfiring all the time... when i move the ignitor around it stops but it still getting a bad signal ( but less than before) and as soon as i let go of the ignitor after a bit it sounds like shit
really its awful
is this becaues i need to replace my ignitor??!
thanks guy any help whatsoever is greatly appreciated!
thedecapitator is offline   Reply With Quote
Old 12-15-2007, 01:45 AM   #2
turbo_duce40
turbo_duce40 is a well-known jackass
it could be that the actual ignitor harness is messing up... this happed to my sr so i ended up going with the splitfire ignition system to fix the problem...
friends dont let friends drive stock!!!
turbo_duce40 is offline   Reply With Quote
Old 12-15-2007, 01:49 AM   #3
thedecapitator
interesting ive never heard of the splitfire ignition system
how much would that cost me?
hey thanks a lot for the reply i really appreciate it +1
Old 12-15-2007, 01:53 AM   #4
thedecapitator
wow is there a cheaper alternative because 525$ for the splitfire ignition system doesnt sound too appealing
anybody with a cheaper alternative??
Old 12-15-2007, 01:56 AM   #5
GSXRJJordan
GSXRJJordan's Avatar
yeah, rewire your harness (or at least check the wiring).
Also, check the grounding strap that sits behind the 4th coilpack - make sure it's grounded to the frame.
Old 12-15-2007, 01:57 AM   #6
thedecapitator
thanks ill check that tomorrow
is there a possiblity that maybe i just need 2 replace the ignitor?
thanks a lot
Old 12-15-2007, 02:10 AM   #7
turbo_duce40
i bought mine for bout 380 on nengun.com shipped to my house...
it might seem like a bit but its really worth it...
Old 12-15-2007, 02:10 AM   #8
GSXRJJordan
Nah if the engine fires at all, the igniter's most likely good. It's a wiring problem 99%. If you were local I could check it out for ya ~
EDIT: The splitfire system is most definitely NOT worth it. The only advantage it has is once you start pushing SERIOUS power, it makes a better spark. None of the big hp SR guys on here need them, and neither do you. Get a harness that works.
Old 01-08-2008, 03:22 PM   #9
thedecapitator
update it was actually a faulty ignitor chip thanks for everyones input
