Old 12-15-2007, 02:56 PM   #1
s13coupePAdrifters
s13coupePAdrifters's Avatar
s13coupePAdrifters has made poor choicess13coupePAdrifters has made poor choicess13coupePAdrifters has made poor choicess13coupePAdrifters has made poor choicess13coupePAdrifters has made poor choicess13coupePAdrifters has made poor choicess13coupePAdrifters has made poor choices
s13 s13 flywheel sliping?
I have just noticed when shifting at higher rpms that my clutch acts as if its disengaged and freely revs before it finally catchs and even when its running normal if i excellerated hard it slips again and freely revs as if in neutral. Is this a flywheel or clutch problem or something completely different. I have a 93 ka24de with a swapped in 5 speed with stage 2 clutch and chromoly flywheel. thanks for any help
s13coupePAdrifters is offline
Old 12-15-2007, 03:00 PM   #2
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
clutch slipping.... If you flywheel were at fault, It would be really rough, and technically, the flywheel "slipping" is not really possible. The clutch can slip, the flywheel is bolted. Shit would be really fucked up if that were the case, and no driving possible.
jskateborders is offline
Old 12-15-2007, 03:14 PM   #3
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
yes sir, get yourself a new clutch
slothonaleash is offline
Old 12-17-2007, 09:38 AM   #4
s13coupePAdrifters
Do you think it could be a bad transmission and the gears slipping cause thats what alot of people have been telling me
Old 12-17-2007, 09:45 AM   #5
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
no its your clutch. only a/t slip.. manuals transmission dont because they have a clutch.
if it were you transmission the synrods (spell check me) would be going out first in those KA trannys
JadeCantDrift Blogspot
i need tires is offline
Old 12-17-2007, 10:09 AM   #6
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
+1 your clutch is going out. Replace clutch and resurface flywheel. Do yourself a favor and replace the pilot and throw out bearings with nissan oem.
-Retired
98s14inaz is offline
Old 12-17-2007, 01:57 PM   #7
silvia13
silvia13 is an unknown quantity at this point
s13
Sound like your clutch. It may be because you maybe getting oil on the clutch from the rear main seal if its leaking or your clutch is going bad.
silvia13 is offline
Old 02-25-2008, 06:17 PM   #8
Phlip
Yes, I look like that
Phlip's Avatar
User was banned because he acted out when someone pointed out that it was a "solenoid" and not a "cellnoid," and I am here to close this thread because he apparently can't spell "slipping" either.
Weirdo
And I write too!
Phlip is offline
