Old 12-16-2007, 01:44 PM   #1
nightshiftgarage
nightshiftgarage's Avatar
nightshiftgarage is on a distinguished road
clutch pedal feels stiff
all of a sudden my clutch pedal is feeling really stiff. it sounds and feels like the spring in the pedal bracket is binding up or soemthing. anyone else ever had this problem, how did you remedy this problem? i sprayed silicon lube on the spring , still didnt help. im thinkin it might be time to but a clutch pedal.
car is a 97 kouki with 191 thousand miles
anyone?
"NIGHTSHIFT-GARAGE"
nightshiftgarage is offline   Reply With Quote
Old 12-16-2007, 01:47 PM   #2
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
anyone?
you sure its the clutch pedal and not the slave or pressure plate causing the resistance? If the spring in the pedal is just bad and grease won't fix it, just get a new a pedal.
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 12-16-2007, 01:53 PM   #3
nightshiftgarage
well i just didnt know if it was gonna be worth it to take out and waste a day of trying to fix or just buy a new one.
the clutch pedal dosent come back out pas the free play of the pedal. its still drivable but feels real shitty. ive made a habit of pulling it all the way out with my toe between shifting.
ive heard if youre clutch cylinder is going , you will have fluid down by the pedal coming down the firewall? true? i was told that by a dsm guy so .........
"NIGHTSHIFT-GARAGE"
Old 12-16-2007, 01:56 PM   #4
A Spec Products
A Spec Products's Avatar
I would try to rebleed the system first
If problem persists, then replace clutch master + slave
They aren't very pricey parts, and are maintenance things you should do anyhow
I just swapped my clutch master + slave the other month, but I had the opposite, it was losing pressure
A SPEC PRODUCTS CORP
Old 12-16-2007, 02:04 PM   #5
MangoDorifto
MangoDorifto's Avatar
MangoDorifto is an unknown quantity at this point
my s14 did the same thing, the pedal feel was horrible and it wouldn't come back all the way. So I also made it a habit of pulling the pedal back with my toe.
I inspected my master and slave (was fine), then readjusted the play in my pedal, removed the damper box, installed a braided SS clutch line, bled the entire system and everything was smooth again with no pedal free play. hope that helps...
MangoDorifto is offline   Reply With Quote
Old 12-16-2007, 02:04 PM   #6
statik
statik's Avatar
my pedal stopped coming all the way back up on my 97, it was the rod/bracket that attached to the pedal, half the bracket was broken, take a peek under there maybe its the same problem
Old 12-16-2007, 02:27 PM   #7
burnsauto
burnsauto's Avatar
sorry to threadjack, but while were on the topic of clutch feel problems..
what if the pedal is just hard to depress?
my pedal is so hard that i could launch crap off it if i take my toe off it when its pressed in..
my setup..
new (but cheap) slave
tokico master
dampener removed
act street/strip
i was thinking it just may be a matter of adjusting the rod from the master that connects to the pedal..or maybe the slave just sucks and i should get an oem one..
Old 12-16-2007, 02:35 PM   #8
nightshiftgarage
ive got a braided clutch line already, ill check the bracket and see if its toast
"NIGHTSHIFT-GARAGE"
Old 12-16-2007, 06:26 PM   #9
nightshiftgarage
ok checked the bracket situation , and to my surprise its none of the above. the little fork piece that threads goes on to the rod coming out of the master cyl. is broken on one side , letting the rod bind up before being pushed in. id assume this will ruin the master cylinder if i keep driving it this way, so tomm. im going to hit up the junk yard and see if they have one or just onight one from the dealer. thanks for eveyones input
"NIGHTSHIFT-GARAGE"
Old 12-16-2007, 06:38 PM   #10
g6civcx
g6civcx's Avatar
Make sure you get a new OEM master cylinder, and not aftermarket or rebuilt. Do a search for details.
Old 12-16-2007, 06:59 PM   #11
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
i know this isnt your problem anymore but i figured id share my pedal return woes as well. the clutch assist spring was worn to shit and the 2 little bushings holding it in had broken apart. it was like 20$ total from the dealer for replacements and it completely fixed my problems so thats another thing to check if anybody else out there has this issue.
smurfgcr is offline   Reply With Quote
Old 12-28-2007, 02:28 PM   #12
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
well, my issue sounds similar.
My clutch pedal is all the way to the floor. i can pull it up, but it drops back down as soon as i touch it.
I want to replace the clutch master and slave anyways...
any suggestions where to buy OEM other than the dealership?
CoasTek240 is offline   Reply With Quote
