Old 12-18-2007, 08:32 AM   #1
pacefarm
pacefarm's Avatar
pacefarm is an unknown quantity at this point
Send a message via AIM to pacefarm
brake fitting help - 300zx bmc 90 degree fitting
monin'
i need some help finding a fitting for the 300z brake master cylinder.
i'm running a boost-designs manifold with a t3/t04e.. when trying to test fit the 300z BMC, i noticed that the brake lines would definately have some clearance issues. i'm already running a non-abs brake booster, so there's nowhere to go.
what i'm looking for is a 90 degree fitting, that would re-direct the brake lines straight down, instead of out towards the block. the fitting should be m10x1.00 male to female 90 degrees, inverted flare.
i tried searching, but no luck. if anyone could recommend a place that would carry this kind of fitting, i'd greatly appreciat it!!
pacefarm is offline   Reply With Quote
Old 12-18-2007, 08:47 AM   #2
g6civcx
g6civcx's Avatar
I'm running the same setup as you: Z32 BMC with braided lines from BMC to caliper.
Earls' have the fittings.
Old 12-18-2007, 09:02 AM   #3
pacefarm
pacefarm's Avatar
do you have any photos of your set-up by any chance?
Old 12-18-2007, 09:03 AM   #4
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
I am also intrested in a pic of ur setup G6.
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 12-18-2007, 09:14 AM   #5
g6civcx
g6civcx's Avatar
It's not anything special. Just regular braided brake hoses with fittings on it.
Old 12-18-2007, 09:24 AM   #6
pacefarm
pacefarm's Avatar
you are running a boost-designs manifold though?
if you are, any problems with heat affecting the brakes?
Old 12-18-2007, 05:16 PM   #7
g6civcx
g6civcx's Avatar
No turbo. Chevy V8 with block hugger headers. Exhaust manifold is nowhere near the BMC.
Old 12-18-2007, 05:28 PM   #8
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
anyone have the part number for the adapter or the thread/pitch?
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 12-18-2007, 05:54 PM   #9
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
Go to a hydraulics store they should be able to make you braided lines right there instore.
240sxScores is offline   Reply With Quote
