injecotrs not spraying fuel
ok i put a greddy intake manifold on my car and i tryed startted the car for the first in about 5 months yesterday. For some reason my injectors are not spraying fuel.. I called Battle ground and he told me to remove fueal turn car over and fuel should come out...didnt
![]() Join Date: Dec 2005
i had this same problem... is ur car a s14 with a s13 sr swap?
also can you hear the fuel pump come on? if you have a walbro you should be able to hear it from the driver seat. |
Check your fuel pump fuse and make sure you put the injectors clips in the correct orientation. Each wire should be shorter than one another with the longest stretching to the #1 injector.
weld drift can elaborate on waht u mean there. the fuse is good.... yes i know the fuel pump is pumping... i cranked the car and loosed line to the rail fuel had plenty of pressure.... but what do u mean about these wires...the first thing i was gonna do was the cam senser...no i have 89 s13 with redtop....
