Old 12-18-2007, 02:27 PM   #1
monkeyslide17
monkeyslide17's Avatar
monkeyslide17 will become famous soon enoughmonkeyslide17 will become famous soon enoughmonkeyslide17 will become famous soon enough
Send a message via AIM to monkeyslide17
s13 motor shakes when car cuts off?
Quick tech question? I have a friend with a 90 s13 hatch. He has told me that, when he cuts the car off the motor shakes. what would this be, we are thinking motor monts. If motor monts how hard skill leavel would you say it is to change the motor mounts with the motor still in the car? can it be done or do you have to remove the motor?
monkeyslide17 is offline   Reply With Quote
Old 12-18-2007, 02:32 PM   #2
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
hehe you sure its not ur car?!
S13Boosts is offline   Reply With Quote
Old 12-18-2007, 02:40 PM   #3
monkeyslide17
Im sure I have a coupe and its a 89. I am asking about a 90 hatch. Thanks for playing.
Old 12-18-2007, 02:44 PM   #4
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
Motor mounts are about as hard as taking some bolts out.. Get an engine hoist and go to town.
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 12-18-2007, 03:03 PM   #5
S13Boosts
S13Boosts's Avatar
just checking. yeah pretty much need a hoist
Old 12-18-2007, 03:28 PM   #6
monkeyslide17
Thanks for that info. Ill let him know.
Old 12-18-2007, 03:34 PM   #7
SimpleSexy180
wait what?
ok your motor is suppose to move a little when u turn it off, thats if u have stock mounts.
if it shakes VIOLENTLY then their is probably something wrong with a mount.
its cake...take out to bottom nuts on the mounts,loosen the top nuts, jack up motor. Once the bottom stud is out of the frame, take off top nuts, remove motor mount and put in new ones. Make sure when you put new ones on to leave the top nut loose so u can play with them as u lower it into the slots.
SimpleSexy180 is offline   Reply With Quote
Old 12-18-2007, 04:10 PM   #8
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Not necessarily but it sure does make the job all that much easier.
Does it shake up on start up and while idling as well? Then mounts most likely.
Old 12-18-2007, 04:56 PM   #9
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
This is what I used to change mine out:
http://importnut.net/nismomm.htm
The only difference is I used 6" 2x4 pieces instead of 12".
Neejay is offline   Reply With Quote
