Old 12-22-2007, 03:44 PM   #1
drifterRS
drifterRS's Avatar
drifterRS is on a distinguished road
kazama sub frame collars
does anyone have like a diy guide for the subframe collars install on an s13?
drifterRS is offline   Reply With Quote
Old 12-22-2007, 04:02 PM   #2
projectRDM
projectRDM's Avatar
Lower subframe, install collars. Raise subframe.
Drive car.
Do you really need a guide for something so simple?
FORMERLY R240NA
Old 12-22-2007, 04:05 PM   #3
240truk
240truk's Avatar
240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about
not very hard, just support the subframe, take off the 4 17mm bolts holding it up, drop subframe a little bit, put in the collars, bolt it back up... done
240truk is offline   Reply With Quote
Old 12-22-2007, 04:07 PM   #4
k's_silvia2.0
k's_silvia2.0's Avatar
k's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfection
Send a message via AIM to k's_silvia2.0
Sorry to barge in but how big is the difference after these are installed?
What gains do you get?Is it just chassi stiffness?
k's_silvia2.0 is offline   Reply With Quote
Old 12-22-2007, 04:20 PM   #5
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
Drive car.
don't forget about the part where you feel every bump on the road....
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 12-22-2007, 04:36 PM   #6
silnismo
silnismo's Avatar
silnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enough
http://www.splparts.com/doc/SubframeCollar/default.htm
benefits are, less wheel hop,and a more solid rear end.
Cons are that they make DD lil more rougher, and extra cabin noise.
silnismo is offline   Reply With Quote
Old 12-22-2007, 04:39 PM   #7
k's_silvia2.0
Which I dont mind
Besides im already deaf due to my Blitz nur spec-R.
Old 12-22-2007, 05:11 PM   #8
ilovecoupes
ilovecoupes's Avatar
ilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to behold
here is another install
http://www.zilvia.net/f/showthread.p...spacer+install
Shoot To Thrill
ilovecoupes is offline   Reply With Quote
Old 12-22-2007, 07:37 PM   #9
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
All true. I have the spl's collars and full urethane...the cabin is noisy as hell. I love it.
-Retired
98s14inaz is offline   Reply With Quote
Old 12-22-2007, 07:41 PM   #10
g6civcx
g6civcx's Avatar
Great improvement over a sloppy stock suspension, but an increase in NVH. We installed a set of these in about 2 hours with basic hand tools and a lot of goofing off. If you focus you could knock it out in under 30 minutes.
Old 12-22-2007, 11:24 PM   #11
silnismo
silnismo's Avatar
Originally Posted by k's_silvia2.0 View Post
Which I dont mind
Then you should man up and get solid subframe bushings and never worry about your collars eventually eating up you stock bushings.
SOLID FTMFW!
Old 12-22-2007, 11:34 PM   #12
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
Yeah use my writeup. Did you search? LOL.
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
Old 12-23-2007, 07:45 PM   #13
drifterRS
drifterRS's Avatar
i searched but i guess i didnt use the right keywords thank you all for you replies it helped out a lot!
