Old 01-09-2008, 10:28 AM   #1
nicku
nicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enough
safc question
Hi,
I tried to set my hotwire sensor type yesterday. I have a s13 blacktop maf, redtop engine and #62ecu. When I changed to 5 in 5 out the car runs the smoothest. But 5in 5out is not for redtop, right?
what's the reason for that?
nicku is offline   Reply With Quote
Old 01-09-2008, 11:22 AM   #2
cotbu
cotbu's Avatar
right!
6in 6out!
wiring? does your tps percentage bounce from 1-3% at warm up or idle?
Failing mafs or wiring, your hacking with an afc already so if the mafs is failing your afc will compensate for the voltage changes, but it may function normally at higher voltage and you shouldn't tune like that.
That's just some crap I made up by the way, i don't know what would happen just doesn't seem logical to do that's all
Test TPS and mafs.
Old 01-09-2008, 11:44 PM   #3
nicku
Originally Posted by cotbu View Post
right!
6in 6out!
Test TPS and mafs.
my tps when the car is warm is about 4.65v something if I am not remembering wrong....
Old 01-09-2008, 11:48 PM   #4
nicku
and I used the dec air function to keep the car away from stalling. I adjusted the throttle to 1.0 % and ne01 point from 4.0 and lowering it down until the car starts chocking. and adjust back on until the car has smooth idle AFTER A NIGHT OF REST on the car. it does help the stalling issue. but when I start the car after a long rest when the car is complete cold, the idle becomes really rough. Is it normal? What should I do when the car idles really rough, should I adjust the ne01 point up a little or just keep giving it some gas until the idle is smooth? or just leave it idle roughly
Old 01-10-2008, 06:08 AM   #5
cotbu
cotbu's Avatar
my tps when the car is warm is about 4.65v something if I am not remembering wrong......
If that's right somethings wrong. I don't pull that at WOT.
The TPS should be .45v give or take w\ engine off key on
Lets get the car running correctly first
Old 01-10-2008, 02:14 PM   #6
nicku
The TPS should be .45v give or take w engine off key on
my bad...actually it is around 0,456 something like that....just went to check today.
but as i said, I adjusted it the dec air function. and it helps keep the car away from stalling, but everytime when I cold start the car ( i mean after a long rest) the idling is really really rough. What should I do?
Old 01-10-2008, 02:21 PM   #7
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
you may have other issues causing your rough idle situation. Leaky injectors/ injector seals are a safe bet on SR's.
RedtopTech is offline   Reply With Quote
Old 01-10-2008, 02:26 PM   #8
nicku
but if i initialize the setting then its fine..
Old 01-10-2008, 02:36 PM   #9
nismo200sx16
nismo200sx16 is an unknown quantity at this point
Send a message via AIM to nismo200sx16
the afc will do that on a cold start. I just turn the decel function off till I get down the road a little. or you could just turn up the ne 1 setting a little.
nismo200sx16 is offline   Reply With Quote
Old 01-10-2008, 02:57 PM   #10
makulit054
makulit054's Avatar
makulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of light
mine does the same thing. I either have to turn off the dec function or turn up NE01 to idle correctly during cold start. anyone else have the same problem? anyone have any other suggestions or answers
makulit054 is offline   Reply With Quote
Old 01-10-2008, 03:37 PM   #11
nicku
icic....and mine does help to keep the car away from stalling, but still....whenever I put neutral to go to a stop, then the rpm goes down to like 500-600 and goes back up to 800. is it normal? or you guys' safc's just make the rpms stay at 800-900??
Old 01-10-2008, 08:11 PM   #12
nicku
nobody has this issue???
Old 01-14-2008, 06:46 PM   #13
drifterken
drifterken's Avatar
drifterken is an unknown quantity at this point
Send a message via AIM to drifterken
nope.. i'd take ur car down to a tuner and have them fine tune the safc... that's wut i did and my car runs prefect without any idle problems..
good luck.
drifterken is offline   Reply With Quote
