Old 01-10-2008, 01:41 PM   #1
SR20n00b
SR20n00b will become famous soon enoughSR20n00b will become famous soon enoughSR20n00b will become famous soon enough
i don't get it??
93 s13 redhead sr20det garrett ar/80 (t25?)
i have greddy fmic with hard piping.
while driving and looking at my apexi avcr boost controller i have the boost set for 0.80 kg/cm2 but when im monitoring getting on it the best i can get is 0.6x or a VERY low 0.7x never have i seen it touch 0.80 it mostly stays 0.5x - 0.6x Also the duty is at 37% should i put this higher? what does it do or should i set it at?
whats going on!?
SR20n00b is offline   Reply With Quote
Old 01-10-2008, 01:50 PM   #2
johngriff
johngriff's Avatar
try messing with the gain.
[email protected]
Old 01-10-2008, 01:53 PM   #3
SR20n00b
gain?
plx explain, im a noob to this
Old 01-10-2008, 02:01 PM   #4
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
gain affects how long the wastegate is held shut in order to get to your boost target quickly. To much gain can result in boost spikes do to the wastegate no opening fast enough to regulate boost pressure.
RedtopTech is offline   Reply With Quote
Old 01-10-2008, 03:22 PM   #5
jspaeth
jspaeth's Avatar
Okay...
I have AVC-R and it is amazing...you just need to learn how to use
Go to settings and pick A or B (whichever you are using)
Turn SELF LEARN on for all 5 gears
Give it a reasonable duty to start at (maybe like 55% or so for 0.8 bar or so)
Then get some pulls in from 2500-redline in like 2nd gear or in third gear from no boost....
After a few pulls, it well automatiucally adjust duty at each RPM (if 55% is a good initial guess) so that it tries to hold 0.8 bar at all the RPM values)
When it suceeds in doing this, it will display "***" under boost duty under settings when you select A or B
Daily driven
Old 01-10-2008, 03:31 PM   #6
SR20n00b
perfect. ill go try it asap. just need to know, what do i hit to turn the 'self learn' on?
