I bent 8 valves : )
Ok I pulled my head off and I bent 8 valves on the intake side. So instead of
replacing the head/valves I'm just picking up a new motor and trans from a 92 dohc 240sx. My only question is what can I use from the 92. I've searched but I cannot seem to source a definite answer. Thanks |
![]() Join Date: Jun 2003
Trader Rating: (130)
be more specific. are you asking what can be salvaged from the old engine? what year engine do you already have? and how the hell did you bend valves? did you reassemble your timing chain way wrong?
what year is the new motor from?
Sale: Hello Kitty Horn Button S14 Rear Valences K.Y. Gordon the Thief (Tony Chen) |
#5 | |
![]() Join Date: Sep 2005
This post makes people stupid
motor and trans!!!!!!!!!!!!!!!!!!! you said you weren't going to replace the bent valves!!!!!!!!!! Quote:
Yes a timing issue bent my valves. Anyway what im trying to say is.... I
found a dohc ka and a trans for 200.00. They are from a 1992 240sx. Im wondering if I can bolt that motor and trans into my s14. It's automatic and so is the 1992. |
![]() Join Date: Mar 2004
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
Yes you can use the s13 dohc in your s14. I can't remember exactly what it is but you will need swap over something from the S14 engine. Maybe intake? Sorry, its been a while since I considered it.
LSX Kouki Project, swap completed in Dec 09 |
yes, that motor will work. You will need to use the S14 intake manifold, sensors, wiring, dist., and the front covers would be in your best intrest as well as doing oil and water pumps and a timing chian kit while the motor is out.
#14 |
Ok I'll start from the beginning. I bought a running s14 for 800.00. And the
only thing was it overheated after about 30mins of driving. So after a few weeks of looking at the problem. I figured the headgasket was blown. After removing the head I found my assumption to be true. So i replaced the headgasket along with all the other gaskets on the upper half of the motor. Anyway... At some point I got a little confused about the camshaft timing which was off a little LOL. So i attempted to fire it for the first time since the tear down and hit a few valves. ![]() |
#15 |
![]() Join Date: Dec 2002
We've discussed this since the dawn of time.
Transmission is identical exact the S13 one will not have a hole drilled for the CPS. Drill it or swap bellhousings. For the engine, you didn't specify what year your car is, but it's *probably* a 95. Swap the water temp sender, exhaust manifold, and distributor. If it's a 96-98, swap the entire intake manifold.
