Old 01-15-2008, 04:58 AM   #1
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
RANDOM ASS JERKING. ughh
It's been happening for a while now.
I get random jerks while driving on the freeway. Usually it's when I hit a small bump in the road - car starts jerking 4 or 5 times, then goes back to normal.
By "jerking", I mean the car feels like it loses power for a bit then gets back on, like the spark is being cut.
If I put it in neutral going over a bump, the RPMs dip & causes the car to stall out as well.
First thing I checked? Knock sensor. I replaced it with a different one, then I hardwired a resistor to the ECU wire. I get nothing.
Cleaned out my IAA with intake cleaner. Doesn't really help.
Checked for loose ground wires. They're all good.
For some reason my car like to misfire at idle as well, but it only does it half of the time. The car shakes back and forth and puffs out the exhaust like it was a cammed big block.
WTF is going on?
Anto is offline   Reply With Quote
Old 01-15-2008, 05:02 AM   #2
hellaflush
hellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to allhellaflush is a name known to all
Send a message via AIM to hellaflush Send a message via MSN to hellaflush
checked your O2 sensor?
hellaflush is offline   Reply With Quote
Old 01-15-2008, 05:09 AM   #3
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
KA24 or SR? I'm guessing hitting the bumps is causing a wire with a loose connection to move....
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 01-15-2008, 05:51 AM   #4
TOMKAIRA93
TOMKAIRA93 is making a name for him/her selfTOMKAIRA93 is making a name for him/her self
I second that koopa.
TOMKAIRA93 is offline   Reply With Quote
Old 01-15-2008, 08:34 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
"ass jerking"? sorry i just thought it sounded funny.
check your battery terminals. make sure they're clean and tight.
(no i'm not trying to be rude or anything, but i see ALOT of electrical problems at work that are nothing more than shitty terminals that are all corroded and eaten away)
Old 01-15-2008, 09:13 AM   #6
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
yeah you have a short or loose connection somewhere.
Pull codes from the ECU
check the ECU harness connector make sure its bolted tightly to the ECU
check wire loom above front left tire to make sure it's not shredded
check your MAF connector
check your CAS connector
check your plug wires & coil wiring if it's a KA.
gl... only so much we can suggest youre gonna have to find the short yourself. Let the engine idle and touch/move every connection you can see until the motor bogs.
MELLO*SOS is offline   Reply With Quote
