Old 01-17-2008, 10:01 AM   #1
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
code 32 problems with new EGR setup.
so lately ive been having peek a boo CEL problems when id be going around 70-75 at 3k rpm, even with a new EGR. i finally pulled the ECU to find out it was code 32.. EGR function, and now ive been having idle problems since the transducer was replaced, what can i do to fix this?
ZenkiKid is offline   Reply With Quote
Old 01-17-2008, 10:26 AM   #2
ma71supraturbo
ma71supraturbo is an unknown quantity at this point
Send a message via AIM to ma71supraturbo
I'm right there with ya. Will be going through this today: http://www.240sx.org/faq/articles/ecm_code_32.htm
ma71supraturbo is offline   Reply With Quote
Old 01-17-2008, 11:31 AM   #3
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
same problem ended up being two things.
1. the hose that connects the transducer was cracked so every once in a while it was leaking.
2. the charcoal canaster had a glog going to the egr witch through a egr code...
i fixed it by blowing out the lines and replacing the hose the. the hose that connects from the transducer to the metal tubing is only about 2 inch's long and is right under the transducer..
if you want to make sure if your egr is getting vacuum turn your car on, put your hand under the egr you should be able to feel the diaphram. rev the engine and feel if it moves..if it dosnt you know its not your problem
deesz is offline   Reply With Quote
Old 02-04-2008, 07:33 PM   #4
redZENKI
redZENKI's Avatar
redZENKI is making a name for him/her selfredZENKI is making a name for him/her selfredZENKI is making a name for him/her self
Somewhat related: can a code 77 (rear o2) set off a code 32?
redZENKI is offline   Reply With Quote
