Old 01-23-2008, 12:30 PM   #1
rb25jun
rb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the rough
Send a message via AIM to rb25jun
windsheild wipers wont work
ok heres my other problem when i got my wiring done for my sr swap.. the wipers were not included... sooo what im hoping is, is there any way i can hard wire the wiper motor to the wiper switch inside the car or is there any real serious way i can get it fixed.. please onces again someone help me out.. i have a 97 s14 kouki with a blktp sr20
rb25jun is offline   Reply With Quote
Old 01-23-2008, 01:15 PM   #2
Ichi-Go
Ichi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymoreIchi-Go is not welcome here anymore
How low is your car. Sometimes your tire eats through the wiring harness on the drivers side fender well causing your wipers to not work and/or other electrical issues.
Ichi-Go is offline   Reply With Quote
Old 01-23-2008, 01:19 PM   #3
g6civcx
g6civcx's Avatar
97 S14s come in 2 models:
non-SE's do not have intermittent wipers.
SE's have intermittent wipers.
Read the FSM. It's easy to wire.
Old 01-23-2008, 02:17 PM   #4
projectRDM
projectRDM's Avatar
You'll need to include the wiper amplifier, the circuit does not go straight from switch to motor.
And to correct the post above, all 97-98 have intermittent wipers. The base model are fixed in one position, SE models are variable, with several settings. Both models are prewired though and only require the addition of the SE switch to add the variable control. 95-96 owners are not so lucky, the base model is not prewired and the amplifier is different between base and SE.
FORMERLY R240NA
Old 02-26-2008, 10:20 AM   #5
farazshah
farazshah is an unknown quantity at this point
Does anyone have a photo or a verbal description of where the wiper amplifier is on a 95 base model? I am having the same problem...and it is snowing here. Would it just be extending the wires from the amplifier output to the wiper motor plug?
farazshah is offline   Reply With Quote
Old 02-26-2008, 10:27 AM   #6
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
The FSM should help - www.phatg20.net has them.
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 02-26-2008, 10:31 AM   #7
farazshah
Already checked FSM, but did not find the location of the amp... If I understood the FSM correctly, it would just be extending wires from the amp outlet to the wiper motor plug inlet.
Old 02-26-2008, 10:43 AM   #8
g6civcx
g6civcx's Avatar
This is correct. Base models have fixed intermittent wipers at 7 second intervals. SE models have variable intermittent wipers adjustable between 3-13 seconds.
As a note, the FSM specs "with intermittent wiper models". I'm not sure if they're implying that some S14s do not have intermittent wipers at all, but so far I haven't seen any. Maybe in Japan or elsewhere.
Old 02-26-2008, 02:40 PM   #9
projectRDM
projectRDM's Avatar
Same place it's located on every S14, right behind the ASCD actuator, beside the wiper motor.
FORMERLY R240NA
Old 02-26-2008, 03:03 PM   #10
shadowexpo
shadowexpo is on the path to ruinshadowexpo is on the path to ruin
whats this about just extending the wires to the amp..is it true?..i had to get the switch off a altima because mine broke..i have a 95 base so the switch doesn't do anything more then the old one but i sure would lik to be able to use the settings if possible..or are they diff..both were posted so who's right?.
shadowexpo is offline   Reply With Quote
Old 02-27-2008, 08:33 PM   #11
shadowexpo
come on guys whats the answer..
Old 02-27-2008, 08:48 PM   #12
soon2bs13
soon2bs13's Avatar
soon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-known
Send a message via AIM to soon2bs13
Rain X my young pad-one
neg repping is cool!!
soon2bs13 is offline   Reply With Quote
Old 02-27-2008, 08:56 PM   #13
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
+1 i have seen this many times, just look up in the fender well and you will know
WangonwWarrior is offline   Reply With Quote
Old 02-27-2008, 09:21 PM   #14
shadowexpo
hahahayea i ready use rain-x they are great by the way..i jus want the option so i dont have to mess with the lever when its only mist or when you need it a lil faster just not to the second setting..
Old 02-27-2008, 09:58 PM   #15
projectRDM
projectRDM's Avatar
What? You have to actually explain what you're asking, we can't read your mind.
FORMERLY R240NA
Old 02-27-2008, 11:28 PM   #16
shadowexpo
my question is if it is possible to use the interval settings for the wipers on the 95 base by just extending the wires to make it work or do you need to get a new amp and wire it up to get the option..i said i have the wiper switch off an altima that has the option for what i want but i can not use it because it is not wired..so again can i just wire it up to make it work or do i need to get the new amp then wire it..
im pretty sure that explains it better..
Old 02-28-2008, 09:05 AM   #17
projectRDM
projectRDM's Avatar
You'll need to run one wire and use the SE amplifier. Read the FSM to see the difference.
FORMERLY R240NA
Old 02-28-2008, 09:09 AM   #18
tanks13
tanks13's Avatar
tanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of light
Send a message via AIM to tanks13 Send a message via Yahoo to tanks13
yo by the way ur motor is a red top
tanks13 is offline   Reply With Quote
