Old 01-10-2003, 07:23 PM   #1
EricP
EricP is an unknown quantity at this point
Sleepy Eye
anyone know how to lazy eye an S13. the 180sx way?!?!?
EricP is offline   Reply With Quote
Old 01-10-2003, 09:03 PM   #2
S13CRAVE
S13CRAVE is an unknown quantity at this point
Send a message via AIM to S13CRAVE
here ya go, this is in the FAQ section under the thread for Free/Cheap Mods:Sleepy Eyes (s13)
1. Make sure headlamps are off and in the "closed" position.
2. Get down on your back and look up through the large opening in the lower front bumper.
3. Look directly under the left and right headlamps and find their electronic plugs.
4. Now while you are down there, you can reach through the large opening and unplug the electronic plugs left and right. You must unplug these in order to adjust the headlamp motors manually.
5. Now get off the ground and pop your hood. You should see a headlamp motor next to each of the headlamps. Looks like a single prong.
6. Pull the cap off each headlamp motor. Now you may manually adjust the headlamp angle at any variable by turning the knob. Make sure that both headlamp motors are evenly adjusted.
7. Now turn your headlamps in the "on" position. Notice the motors dont move and the headlamps simply light up. Viola, instant "sleepy look."
**Now in order to get the headlamps in its original position you have to manually adjust the headlamps in the "closed" position via the motor. Then plug the wiring back together.
And btw, it is usually called Sleepy Eye. Lazy eye is if you have a medical problem with you eyes, lol.
Or you can buy a Pivot Headlamp controller, it's a waste of $100 IMHO. I just did it the cheap way above.
~Ian
S13CRAVE is offline   Reply With Quote
Old 01-10-2003, 09:05 PM   #3
EricP
oh ya. Sleepy Eye. anyways thanx
Old 01-11-2003, 03:51 PM   #4
89180SXse
89180SXse is an unknown quantity at this point
theres an easier way to do it, but it might not be very straight as one eye might be lower than the other.
you should do a search me and several other ppl explained it in detail
89180SXse is offline   Reply With Quote
Old 01-11-2003, 11:19 PM   #5
RedStage
RedStage's Avatar
RedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to behold
Here....this is a little more
time consuming in the beginning....but once done...no more messing around.
http://www.geocities.com/velocityyok...180lights.html
Enjoy. DIY. Just be sure you double check your wires. Not 100% sure if the USDM wiring is the same color codes.
Marc - Yokohama, Japan
RedStage is offline   Reply With Quote
Old 01-12-2003, 08:45 PM   #6
sponger85
sponger85's Avatar
sponger85 is an unknown quantity at this point
Send a message via AIM to sponger85 Send a message via Yahoo to sponger85
how can i check the wires?
92 240sx FB: 5 Speed baby
Champagne NOT gold
the reason i got the s13 over the s14 is def. bc it had automatic seat belts ....
www.fungbodyboarding.com ... check it out
sponger85 is offline   Reply With Quote
Old 01-13-2003, 02:47 PM   #7
RedStage
RedStage's Avatar
Pull the switch....
If the wires are the same, you should be good to go.
A buddy of mine did his first. He checked them with a volt meter.
I'll have to get ahold of him and ask him what clued him into which wire to cut.
Give me a day or so.
Old 01-13-2003, 03:02 PM   #8
sponger85
sponger85's Avatar
aight man thanks ...
Champagne NOT gold
Old 01-13-2003, 09:32 PM   #9
hybrid240
hybrid240's Avatar
hybrid240 is an unknown quantity at this point
i want my headlights to lay flat when off and come half up when on. i guess ill have to get Pivot Headlamp controller or the replacement lights from autoimaging.
boostin through a neighborhood near you!
hybrid240 is offline   Reply With Quote
Old 09-14-2003, 12:48 PM   #10
rps13sh
rps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nice
Send a message via AIM to rps13sh
with a test light. its the green wire.
rps13sh is offline   Reply With Quote
Old 09-14-2003, 02:23 PM   #11
HKrpS13
HKrpS13 is an unknown quantity at this point
Send a message via AIM to HKrpS13
The pivot headlight control adjusts the height when the headlights going down so I don't think this is what you're looking for.
HKrpS13 is offline   Reply With Quote
Old 09-16-2003, 12:55 AM   #12
RadicalEdward
RadicalEdward can only hope to improve
Send a message via AIM to RadicalEdward
my ghetto way to make sleepy eyes is here:
http://www.zilvia.net/f/showthread.p...760#post314760
RadicalEdward is offline   Reply With Quote
Old 09-16-2003, 08:37 AM   #13
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
8 month old thread
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
