Old 02-05-2008, 09:15 PM   #1
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Pilot Bearing Woes...
I'm in the process of a 5 speed swap and the only thing keeping me from completing this shit is the pilot bearing/bushing. Two of the pilot bearing pullers from AutoZone already snapped on me. I'm on my third (brand new) puller and it's just not grabbing. I don't want to tighten it even further because I have a feeling it'll just snap like the others, but the sucker just slides out when using the slide hammer.
Anyone know another method or maybe tell me if I'm doing something wrong? Really want this car back on the road. I miss my car .
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 02-05-2008, 09:27 PM   #2
EAT Motorsports
EAT Motorsports's Avatar
EAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of light
Send a message via AIM to EAT Motorsports
grease gun style pilot bearing puller is what i use
http://www.matcotools.com/Catalog/to...&page=1&#36678
EAT Motorsports is offline   Reply With Quote
Old 02-05-2008, 09:37 PM   #3
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
i tried the bearing puller and all the home remedies including hydraulic pressure with grease and what not, and they all sorta worked, but not enough...so a few beers deep into the night a long time ago i came up with the idea to take a drillbit and work it over the inside of the bearing until it was worn down enough to be seperated with a flathead and pulled out in pieces. it was a messy job, not to mention extremely stupid, but it worked...
beer is a good last resort
smurfgcr is offline   Reply With Quote
Old 02-05-2008, 09:41 PM   #4
DreamN
DreamN's Avatar
Trader Rating: (54)
So you pump grease where the pilot bushing goes into? I'm not completely grasping how it works.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 02-05-2008, 09:44 PM   #5
EAT Motorsports
hydralics... basicly the pressure of the grease behind the bearing pushes it out from behind.
Old 02-05-2008, 09:46 PM   #6
smurfgcr
the ghetto way is stuffing grease in there where the bearing is and find a cylindrical object that fits in there snug and tapping it. the hydraulic pressure is very strong pushes out wherever it can so theoretically it pushes out the bearing. doesnt work too well IMO. theres some stuff floating around zilvia which can give you some more ideas on how/what to do.
Old 02-05-2008, 09:48 PM   #7
aznrib
aznrib is making a name for him/her selfaznrib is making a name for him/her selfaznrib is making a name for him/her self
The pilot bearing puller from auto zone will not work with the pilot bearing on the auto trans. The pilot bearing on the auto trans is longer compared to a manual one so the puller does not reach. What I did was cut slits into the bearing with a dremel and then tap it out.
aznrib is offline   Reply With Quote
Old 02-05-2008, 09:52 PM   #8
nosajton
nosajton is on a distinguished road
does it have the auto bushing in it right now? if so get a air chisel and hit it from both sides.. it will pop right out. take 5 seconds.
if it is the 5 speed bushing, i used the special snap on pilot puller.
nosajton is offline   Reply With Quote
Old 02-05-2008, 09:55 PM   #9
Infamax
Infamax's Avatar
Infamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enough
One method is using a thick grease and a bolt the same diameter as the inner diameter of the pilot bushing. You pack the crap out of the bushing with grease and then hammer in the bolt into the bushing hole. The pressure applied to the grease without a way to exist will push on the pilot bearing from the inside and force it out.
or
Method two is to get a drill and drill out or carve out the busing into 2 pieces. Drill across the top of bushing and across the bottom until both sides are worn down. The metal the bushing is made of is soft enough for you to be able to carve into. You don't necessarily need to carve through the whole pilot bushing, just enough to weaken its integrity.
Infamax is offline   Reply With Quote
Old 02-05-2008, 10:04 PM   #10
jhec23
jhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nice
Times like this, Dremel is our best friend. I did mine differently though, I had to shaped the puller I rented from auto zone with my dremel to make it fit good into the pilot bushing before pulling it with the slide hammer.
jhec23 is offline   Reply With Quote
Old 02-05-2008, 10:06 PM   #11
CSXTacy
CSXTacy's Avatar
CSXTacy has a little shameless behavior in the past
sounds like you are having a bad run with pilot bearing pullers. just last night i installed a clutch on my buddies sr and bought a puller from the local snap on truck. granted it was 150 bucks but within 1 minute that bearing was out in one solid piece. the price for the tool was high but definatally worth it in the headache i saved trying to fanaggle it out of there with any thing else. just keep trying i guess thats all i can say. sry im not much more help. GOOD LUCK!!!
CSXTacy is offline   Reply With Quote
Old 02-05-2008, 10:30 PM   #12
DreamN
DreamN's Avatar
Trader Rating: (54)
Well, I don't think length is the problem. I think the fact that the teeth on the puller just won't grab onto the edge/groove of the bushing. Either way they AutoZone pullers are shitty.
Yes, it's the auto bushing that I'm having trouble with. An air chisel? I'll consider it, but I really wouldn't want to use any type of power tool on it.
Ahh, alright I get it. I think this might be doable then. Did a quick search and those grease guns aren't all that expensive plus it'd probably come in handy iin the future.
Went onto the Snap-On site and only found the same kind of puller that AutoZone rents out.
http://buy1.snapon.com/catalog/item....re&dir=catalog
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 02-05-2008, 11:19 PM   #13
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
like they said, i used a dremel. cut it in pieces and then use a flathead and get it out
lexus baby
5t341tH is offline   Reply With Quote
Old 02-06-2008, 03:46 AM   #14
DreamN
DreamN's Avatar
Trader Rating: (54)
Well, I was able to get it off. What we did was cut the bearing on two opposite sides using a dremel to create to flat surfaces. Using an adjustable wrench we broke the bearing loose and then used the same autozone puller we were using before. I understand now what aznrib was saying about how the puller is not for the A/T bearing. The groove on the A/T bearing doesn't allow for the puller's claws to get a proper hold of it because of the lack of lip. It's meant to be used on the M/T bearing.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 02-06-2008, 08:09 AM   #15
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Those bushings are different for everyone. It also depends on where your car has been. High humidity environments will cause moisture to build up causing surface rust which effectively seals those bushings in. I used the three prong bushing puller from Harbor Freight. It has worked on the 3rd-5th try every time I have used it on the auto bushing. The handful of times it failed I bought a fresh puller, put the old one back in the box, and took it back. I've never had to cut one out. The 5spd bushings are nice and soft. A few well placed blows with a hammer and chisel gets those right out. Like it was mentioned earlier in the thread, you just need to ruin the integrity of the 5spd bushing.
-Retired
98s14inaz is offline   Reply With Quote
Old 02-06-2008, 08:36 AM   #16
Dream240
Dream240's Avatar
When I did my auto/manual swap, I had just as bad of a time.
I used my dremel and the larger of the two sanding wheel attachments. Just sand the bushing down from the inside until it's thin enough to grab with vice grips. The vice grips should crush the bearing by grabbing the portion that sticks out of the hole and just clamping it down nice and tight. Once the integrity of the bushing is compromised, it should come out pretty easily.
The crappy part is the time it takes to sand through the bushing. Took me about 45-60 min. You have to pay special attention to where the dremel is at while you're sanding. You don't want to accidently dremel the inside of the crank hole....cause that would be bad.
And yeah the puller I bought from harbor freight works wonders on the manual pilot bushing. Takes less than 5 minutes everytime, and only cost me 10 bucks!!
Gotta love Chinese importers.
Old 02-06-2008, 08:40 AM   #17
Saucy240
Saucy240's Avatar
Saucy240 is an unknown quantity at this point
Wouldn't that be exporters?
Saucy240 is offline   Reply With Quote
Old 02-06-2008, 09:48 AM   #18
aznrib
glad you got it off. Gl on your project
Old 02-06-2008, 11:09 AM   #19
Dream240
Dream240's Avatar
No, importers. I'm referring to the companies over here that BUY the stuff.
Old 02-06-2008, 03:43 PM   #20
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
I couldnt get mine out so i tacked a nut to it and threaded a long bolt into it and used a slide hammer... I wouldn't suggest this as there is a seal you can render useless if done wrong but it was an exercise in precision welding
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 02-06-2008, 03:55 PM   #21
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
iv'e use heat (torch) and a puller also i have very carefully welded a bolt to thethe bearing on motors that have that nasty pilot bearing
georgesal is offline   Reply With Quote
Old 02-06-2008, 04:34 PM   #22
LFOabuse
LFOabuse's Avatar
LFOabuse is making a name for him/her selfLFOabuse is making a name for him/her self
Both Autozone and Pep Boys rent a higher end bearing puller that works extremely well. It's called a "blind hole puller". It is a set of 4 different sized attachments and a slide hammer. The two times I have used it the bearings have popped out on the second or third hit of the slide hammer, minimal effort. It rents for about $120 cause it's a really nice kit, but you get your money back when you return it of course.
The "bearing puller" on the Autozone "rental chart" is absolute garbage. Most AZ employees don't know about this kit because it isn't on their tool rental chart. Rest assured they will have it although you may have to go in the back and find it yourself, just like 90% of stuff in AZ.
LFOabuse is offline   Reply With Quote
Old 02-06-2008, 04:48 PM   #23
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Here what I use when im doing an auto to 5 speed swap I think some people will find this useful:
To remove the auto pilot bushing I use a 1/2" extension with a 9/16" socket that has been slightly (modified) grinded to fit snugly into the auto pilot bushing and then simple push down and and pull up repeaditly until it wiggles it self loose, this works good!
Next to install the manual pilot bushing without damaging it first I soak the pilot bushing in motor oil for about 15-20 minutes for godo measure, then from my auto transmission I jack the input shaft from it which pulls right out (which can also be seen in teh pictures) use this to install the pilot bushing by placing the manual pilot bushing over the shaft and gentle tap with a hammer or mallet.
Old 02-06-2008, 04:56 PM   #24
DreamN
DreamN's Avatar
Trader Rating: (54)
Thanks to all who replied. Good ideas if there's ever a next time or for others viewing the thread.
LFOabuse, good to know. I asked if there were others, but they said that was the only one they carried.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 02-06-2008, 05:20 PM   #25
motronic
motronic is making a name for him/her selfmotronic is making a name for him/her self
I did it just like UNISA on my auto SR. I actually was in the same boat after I couldnt pull the pilot bushing using 2 diffferent puller and slide hammer etc.
I searched here and found that someone managed to do it by inserting a pipe that fit snug on the bushing and start wiggle it up and down. When I saw that I thought it was impossible and ridiculous but decided to try it anyway since the only option left is cutting/drilling it out.
I used my craftsman jack handle and start wiggling it, after about 10 mins I can see it start to sticks out and finally in 20 mins it was out. I didnt believe my eyes but it works.
motronic is offline   Reply With Quote
Old 02-06-2008, 05:27 PM   #26
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Awesome, I think it took me about 1-2 minutes I used a hammer to tap the 1/2" extension up and down to get it started and soem PB Blaster.
Old 02-06-2008, 05:40 PM   #27
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
A dremmel should only take 5 minutes or so if its really stuck. I've done it a few times, cut a triangle into the inside of it and it will pretty much fall out.
KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST
lilredstiffy is offline   Reply With Quote
