Old 02-13-2008, 11:53 PM   #1
bram StRoker
bram StRoker is an unknown quantity at this point
skyline turbo questions??
Does anyone know the specs on a stock R34 skyline turbo? i know its a t28 ball bearing and says .48 as opposed to .60 s15 turbo. and it has to be bolted to a top mount manifold. ive heard of people running between 21-25 psi with no problems whereas the s15 isnt recommended to go over 15. but does anyone know the actual max recommended boost? is anyone running them on an sr20? how much hp can u expect? interested in mounting it i also have an s15 turbo is it worth it to switch
bram StRoker is offline   Reply With Quote
Old 02-14-2008, 12:08 AM   #2
LongGrain
LongGrain's Avatar
are you talking about the RB25 turbo, or an RB26.
LongGrain is offline   Reply With Quote
Old 02-14-2008, 12:16 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I think you got the 2 mixed up...R34 GTR turbos dont like going over 1 bar. Ceramic fins have a tedency to explode after 1 bar...stay with the S15 turbo and boost to 1.2.
CLICK HERE!!!
Old 02-14-2008, 08:03 AM   #4
bram StRoker
i probably will stay with the s15 turbo but how can u tell if its ceramic? looking at both turbos off the car they look identical except one says a/r.60 and a/r.48
Old 02-14-2008, 08:28 AM   #5
slidingsky
slidingsky's Avatar
slidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfection
It doesn't have to bolted to a top mount manifold but I seriously doubt someone is running 21-25 psi on those turbos.
slidingsky is offline   Reply With Quote
Old 02-14-2008, 01:15 PM   #6
bram StRoker
How do you get it to bolt up to a bottom mount manifold? I tried a megan, hks, and the stock manifold. None of them fit. The compressor side runs into the runners. do you need a spacer(kinda like a flange adapter)? if not how do you re clock it because if u rotate the compressor housing there is no where to bolt the actuator
Old 02-14-2008, 02:20 PM   #7
slidingsky
slidingsky's Avatar
Try using an SR20 Wastegate actuator I'm pretty sure that is the solution once you clock it. I'm not familiar with R34 stuff but if it is the same as the 33's then that is money.
Old 02-15-2008, 06:21 AM   #8
bram StRoker
sweet i try that. thx
Old 02-15-2008, 06:26 AM   #9
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
just invest in a better turbo...my car made 290 whp at 12 psi with the 2871r .86 most s15 bb dont even make that at 18
just go ahead and get a 2871r .64 atleast
((sr)) kelly is offline   Reply With Quote
Old 02-15-2008, 07:01 AM   #10
bram StRoker
i would but im saving up for a gt35r. i just needed a turbo to tune my aem ems on for the meanwhile because my bitch ass t25 blew up on me.btw what engine management are u on
Old 02-15-2008, 04:32 PM   #11
hijack3d
hijack3d's Avatar
hijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond repute
RB turbos are specific to RB only... you'll need to fabricate to make it work, and it's def. not worth the effort.
Don't worry, it's legit: Review (Thanks Mike)
hijack3d is offline   Reply With Quote
Old 02-15-2008, 04:34 PM   #12
((sr)) kelly
yeh man.. just grab a s14 t28 then....
and im using a PFC
Old 02-15-2008, 05:52 PM   #13
bram StRoker
Ya no problem.. Its a shame tho because the turbo r34 only only has 6k miles on it where as my s15bb has like 65-70k. As for fabricaton what would be needed to make it work because a buddy of mine is interested in buying it? is it just a spacer so the runner doesnt hit the turbo and a different compressor out flange because i already made one out of an old greddy bov flange and a 90 degree bend pipe? any info will be helpful.
