Old 02-21-2008, 07:33 PM   #1
mxsx25
mxsx25's Avatar
mxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-known
Send a message via AIM to mxsx25
SR sr backfires/misfires at full throttle??
the only mod really done to the car is an hks wastegate and to my understanding it is set for 10 lbs, also has an apexi boost controller but i initilized it so it shouldnt be affecting anything...
anyways, under part throttle the car revs all the way up fine, but once i put it to the floor it starts to sh*t all over the place lol... any ideas?
mxsx25 is offline   Reply With Quote
Old 02-21-2008, 09:38 PM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
vacuum/boost leak. a small one. possibly an intake gasket or hairline crack in the manifold, maybe a leaking injector-manifold grommet *shrug
i'd start by checking intercooler couplers for rotting/cracking, and tighten the clamps while you're inspecting em.
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 02-21-2008, 09:40 PM   #3
sliEighty
sliEighty's Avatar
sliEighty is making a name for him/her selfsliEighty is making a name for him/her self
Send a message via AIM to sliEighty
boost leak... i had the same problem
livin on the east cost is harder then you think...
ECM for life lll
sliEighty is offline   Reply With Quote
Old 02-21-2008, 10:32 PM   #4
91drftr
91drftr's Avatar
91drftr has made poor choices91drftr has made poor choices91drftr has made poor choices91drftr has made poor choices91drftr has made poor choices91drftr has made poor choices
Talking same problem simple solution.....
my friend had the exact same problem, wec also thought it might be boost leak problems or fuel but to make long story short the last thing we did is that we switched out the spark plugs with some new ones and that did it, we were flooring it all over the streets no problem, its been running great ever since.....
91drftr is offline   Reply With Quote
Old 02-23-2008, 08:02 AM   #5
mxsx25
mxsx25's Avatar
say it is a boost leak... besides visual inspection, how do i go about pressure testing the system for leaks?
Old 02-23-2008, 10:56 AM   #6
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
make a cap w/ nipple and use air comp to fill air into the system
listen for leaks or at idle spray carb cleaner and if idle fluates, theres the problem
at wat rpms does it misfires
i had this problem last week
usually misfire relates to coilpacks, coilpack harness, ignitor, or grounds
for me after confirm all those parts were in working order, i finally decided to swap a new engine harness which fixed the problem (motor misfires after 5k or 5500k)
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 02-23-2008, 10:59 AM   #7
Sonic Motor
www.SonicMotor.com
Sonic Motor's Avatar
Trader Rating: (113)
Sonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfection
Feedback Score: 113 reviews
Send a message via AIM to Sonic Motor
3 letters, T P S
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK )
Sonic Motor is offline   Reply With Quote
Old 02-23-2008, 11:01 AM   #8
vutony
vutony's Avatar
yes, i forgot
check timing
i do SR wiring
Old 02-23-2008, 11:18 AM   #9
mxsx25
mxsx25's Avatar
yeah it ONLY backfires/misfires under wide open throttle acceleration... around 4500 to 5k... im gonna get her to buy some new plugs and then if that doesnt do it... ill swap the coils out of mine and see if that does the trick... also, she has one of those cheap ass ebay fmic's and i honestly wouldnt doubt if that P.O.S leaks threw the welds and what not... so we'll see, thanks for the help guys! keep it comin!
Old 02-23-2008, 09:46 PM   #10
Synicals13
Synicals13's Avatar
Synicals13 has made poor choicesSynicals13 has made poor choicesSynicals13 has made poor choicesSynicals13 has made poor choicesSynicals13 has made poor choicesSynicals13 has made poor choicesSynicals13 has made poor choices
its crazy cuz i just got my car up and running again and i have the exact same problem. With the exeption that my car is running rich due to the bov.
Im gonna switch out the spark plugs tomorrow, i'll let ya'll know how it goes.
Synicals13 is offline   Reply With Quote
Old 02-23-2008, 10:25 PM   #11
SixSpeedSleuth
SixSpeedSleuth's Avatar
SixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to behold
Check the spark plug gap as well as base timing, and what others have suggested, boost leak.
SixSpeedSleuth is offline   Reply With Quote
Old 02-23-2008, 10:30 PM   #12
mxsx25
mxsx25's Avatar
i put bran new plugs in, and swapped the coils out of my own car (which i know are all good and near new) and still the same fu**ing problem! she has a p.o.s fmic so maybe thats leaking, i havnt figured out how to pressurize the system to test for leaks yet, anyone got a pic on how they did so? it must be that since it only does it under full boost/ full throttle
Old 02-23-2008, 10:33 PM   #13
SixSpeedSleuth
Were the plugs pre-gapped? I had a similar problem of the car breaking up/misfiring in the upper rpms, checked my plugs (gap was way off), gapped them to .028 and that immediately fixed my problem. But, if that does not fix it, it def sounds like you have a boost leak somewhere.
Old 02-23-2008, 10:40 PM   #14
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
i've been researching on how to make one myself. this should do the trick. the two different links go about it in two different ways. have fun!
http://www.vfaq.com/mods/ICtester.html
and
http://www.stealth316.com/2-pressuretester.htm
have you checked timing yet!? it takes like 5 seconds. also make sure your TPS is calibrated right. if you don't have an FSM PM me, i have it hosted on an FTP server.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 02-23-2008, 11:32 PM   #15
Z U L8R
Z U L8R's Avatar
ngk bcpr7es or bkr7e gapped at .028 ftw
Dave =]
Old 02-24-2008, 09:50 AM   #16
mxsx25
mxsx25's Avatar
im going to go out and make a pressure tester today thanks to unicoladron! great how-to's on those links... as well as check the plug gaps and what not...it must be a boost leak i think though...we'll find out today if she's leakin! thanks for the help guys!
Old 02-24-2008, 01:39 PM   #17
mxsx25
mxsx25's Avatar
so i just made my own pressure testing device... and i found boost leaks from the bov itself , the flange, the tb gasket, the vacuum ports coming from the intake manifold...and little hoses, so alot of them... and to top it all off, as im writing this messege, my dad comes up and tells me he backed into the side of the car in the garage with the tahoe.... well heres some pics...
in the picture below, the places where i felt a leak coming from are circled... im curious about the one with the arrow going to it though, its all tweaked and such, are those removable? i dont want to break them or something in case they arent..
when i pressurized the system air was going crazy out of that little hole i have circled on the bov?? is something supposed to be there? it seems like thast how it always was?
my little contraption worked quite well
Old 02-25-2008, 07:56 PM   #18
mxsx25
mxsx25's Avatar
anyone have any advice on these pics?
Old 02-25-2008, 08:07 PM   #19
dingwing
dingwing is an unknown quantity at this point
i had the same problem with my car. i dropped my gas tank and pulled out the fuel pump and the little filter on the fuel pump had little metal peaces in it. i replace the fuel pump and my car has been running fine since then.
dingwing is offline   Reply With Quote
Old 02-25-2008, 08:30 PM   #20
mxsx25
mxsx25's Avatar
damn it could be so many things lol
ill just do everything then!
Old 02-25-2008, 09:17 PM   #21
vutony
vutony's Avatar
plug them up
i have my fpr, bov, boost gauge connected to the tb
as for the vac leak test, i have it capped off to the intake (not hotpipe)
i do SR wiring
Old 02-25-2008, 09:18 PM   #22
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
I have mine to the intake as well, works good to catch any leaks on the hotpipe. I ended up getting 2 for in that area.
duffman1278 is offline   Reply With Quote
Old 02-25-2008, 09:54 PM   #23
mxsx25
mxsx25's Avatar
the bolt on cyl#3 coilpack was broken and i was told that may be a problem due to having a bad ground...?
i got one of the vacuum ports out, but the other broke... drill and remove? or just thread a bolt in to plug it up?
also, the greese on the flange leeds me to beleive that there must be a leak at the flange? anyone have any thoughts on this..
Old 02-26-2008, 10:12 PM   #24
mxsx25
mxsx25's Avatar
so i fixed the problem, not sure what fixed it though since i did a couple of things... i made sure there were no more boost leaks for one, plugged an open nipple which was after the maf yet before the turbo, and realized there was a broken bolt on the #3 coil pack so i fixed that and then installed a diy grounding kit for the coils and she purrs like a kitten at all times, all i have left to do is recirc. the bov becuase it almost wants to die on decel after heavy throttle... anyways, thanks for the help guys
Old 02-26-2008, 10:25 PM   #25
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
If the grease at the flange of your bov is due to a leaky bov, you have a bigger problem than a boost leak
"I am Norwegian, and are not familiar with your urban words :P"
jskateborders is offline   Reply With Quote
Old 02-28-2008, 07:35 PM   #26
mxsx25
mxsx25's Avatar
yeah there might be a bad seal on the turbo but im not too worried about it RIGHT this second, she bought a gt2871r with the .60ar housing so that will bolt up but im not about to put that on with stock injectors (the kid that told her to buy it said it was an easy bolt on and drive project) lol i wish, we'll see what happens
