Old 02-21-2008, 03:32 PM   #1
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
SR I'm getting seriously frustrated. Sr20 wont fire
93 nissan 240sx with red top sr20, i blew up my motor rebuilt it and put everything back together, i am not getting a spark at all, engine will not fire. I was told before to check my wiring, my ignitor, and my ECU. I pulled the entire wiring harness re did it and re-installed it, i replaced my ignitor, i replaced my ECU. I am still not getting any spark, and the engine still does not fire. does anyone know the voltages for the power wire and signal wire at the coils and does anyone know the voltages my CAS should be recieiving and putting out.
Thanks, Landin
landins13 is offline   Reply With Quote
Old 02-21-2008, 03:37 PM   #2
SoSideways
SoSideways's Avatar
Get a hold on an S14 w/ SR20DET FSM... everything's in there...
Old 02-21-2008, 03:40 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
You should get a KA.
Distributors rawk.
Old 02-21-2008, 03:44 PM   #4
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
^^ I agree NemeGuero.
SnakeKack is offline   Reply With Quote
Old 02-21-2008, 03:57 PM   #5
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
Hahaha. Unhelpful bastards! Grab a multimeter and trace where the power is going and where its not going. Maybe your cross some wires wrong.
Vision Garage is offline   Reply With Quote
Old 02-21-2008, 06:01 PM   #6
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
there is also a diagnostic procedure you can use by connecting LEDs to your ignition (somwhere near coilpacks) then pulling your CAS, turning it by hand, and seeing if the LEDs flash. someone chime in if they know what i'm talking about. i know i didn't make this up. the procedure may be in the electrical/ignition section of the FSM. this will determine if you have a bad CAS. it could also be your ignition wiring, i remember hearing of issues with that.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 02-21-2008, 06:06 PM   #7
landins13
landins13's Avatar
ive checked all of the wiring, the car was running without a problem until it blew up, none of the wiring was changed, and i removed all of the wiring once i started having this problem and inspected it for problems. The wiring is good. I'm having trouble getting a hold of a repair manual, if you have any sites or suggestions let me know. and the procedure i think youre talking about would be using a timing light, but that wont really help me with getting a fire, unless im thinking of something different. I really appreciate the insight, if you have any other suggestion please let me know.
Thanks again, Landin
Old 02-21-2008, 06:18 PM   #8
onyxaltezza
onyxaltezza is making a name for him/her selfonyxaltezza is making a name for him/her selfonyxaltezza is making a name for him/her self
Timing? Distributor?
-Aaron
onyxaltezza is offline   Reply With Quote
Old 02-21-2008, 06:25 PM   #9
johngriff
johngriff's Avatar
Take out the cas, spin it. Are the injectors clicking?
Test continuity from the ignitor chip plug (ecu harness side) to the ecu. Test the coil pack harness the other way. Do this by using a resistance test, if the resistance is too high, I am guessing its bad.
Um, Check for power on the injector wires. If no injectors + no coil packs, probably a bad egi relay.
[email protected]
Old 02-21-2008, 06:27 PM   #10
unicoladron
-Aaron
his SR20 doesn't have a distributor, it uses a camshaft position sensor.
but i swear there was some other procedure..but now that makes me thing of something else. i'm still stuck on the CAS, because it's the only part of your ignition system you haven't tested. here is a procedure from the FSM, the procedure i was thinking of was for injector pulse i think...oops. but here try this maybe:
is your mechanical timing in spec?
how do you know you're not getting spark? did you crank the engine with your coil packs out with an extra spark plug and hold it ~1 inch from your valve cover and look for an electric pulse while cranking?
Old 02-21-2008, 06:29 PM   #11
unicoladron
ahhh! did you check your ecu for codes too!? if you haven't yet, check now!
Old 02-21-2008, 06:56 PM   #12
johngriff
johngriff's Avatar
It is not sparking.
Its also not going to generate codes until it runs probably..
[email protected]
Old 02-21-2008, 07:12 PM   #13
WISH ONE
Im getting sick of my sr also! bELIEVE ME! i have a similar problem, fuel spark and to my knowledge timing is there, but no firing at all. anyone wanna buy an sr set up lol. good luck keep us posted.
Old 02-21-2008, 07:25 PM   #14
mestizo
mestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the rough
THis may sound like an obvious and stupid comment but did you check your fuses and grounds?
92 S13 Coupe Track Car
mestizo is offline   Reply With Quote
Old 02-22-2008, 01:50 AM   #15
WISH ONE
check your cas?i tested it the first time and all the injectors seemed to pop fine when i spun it on second look i finally figured out why mine wouldnt start i tore my cas apart and the metal disk inside had a little hole burned out of it.
Old 02-23-2008, 12:39 AM   #16
landins13
landins13's Avatar
ok so here is the update. all of my wiring is good, i pulled the entire harness again and rechecked its all good. I havent checked my CAS but i have a slightly larger concern after talking to a friend of mine that is a master tech for mercedes. he listened to it turning and said it almost sounds like im getting not compression, so tomorrow im going to compression test it. Ive done the ignition spark test as described above, i finally found a FSM for my car, its for an s14 but hopefully it will help me with my redtop. Um as far as anything else....ignitor is new, starter is new, ECU is new, i also have a mines ECU (IN CASE ) oh im definitely getting fuel, my timing is perfect, im just kind of at a stand still, i'm feeling like its gotta be something with the coils and/or the CAS hopefully its something simple cuz those are both expensive and im really not trying to give up on this thing. My fault though, i was making stupid power on stock internals and i ran the motor almost dry so yeah.
I appreciate all the help guys really, ill keep updating with any news.
Old 02-23-2008, 12:42 AM   #17
landins13
landins13's Avatar
forgot to mention, i checked the fuses and grounds. Sorry, ive done a lot in the past few days plus work, school, snow, flu, im pretty sure ive lost my mind.
thanks, landin
Old 02-23-2008, 08:15 AM   #18
mxsx25
mxsx25's Avatar
mxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-known
Send a message via AIM to mxsx25
if your deffinately getting fuel, than that means the cas should be good, ohm test your coil packs , and is your igniter BRAN new or just bran new-second hand lol could be faulty... i had sorta the same problem for a while, and it ended up being both my cas and igniter
mxsx25 is offline   Reply With Quote
Old 02-23-2008, 12:50 PM   #19
hstylez
hstylez's Avatar
hstylez is on the path to ruinhstylez is on the path to ruin
Recheck grounds. I had no spark when I didn't have a ground on my valve cover...
S13 Coupe SR20DET
hstylez is offline   Reply With Quote
Old 02-23-2008, 01:52 PM   #20
cotbu
cotbu's Avatar
Good save!
I say. if it's not an obvious problem, reverse engineer it! Look at all the things that would cause your car not to start under normal circumstances.
Also you must mean mechanical timing is perfect, because you haven't started the car yet. What was the results of the compression test?
Pop in the other ecu to maybe eliminate an ecu problem. I'd really like to hear the sound it makes when your trying to start it.
I also have a shit load of tests that I would have you do, but that's just redundant at this point.
Continuity test the harness would be #1 before the ecu swap.
Old 02-23-2008, 02:01 PM   #21
johngriff
johngriff's Avatar
Sounds like it has no compression? You would know.
Fuel + Spark + Compression = Run. Its got to be one of those 3.
[email protected]
Old 02-23-2008, 02:48 PM   #22
blownmotor
blownmotor's Avatar
blownmotor is on the path to ruinblownmotor is on the path to ruin
you probably could have flooded the combustion chamber from all those times of cranking pour some oil in to each cylinder before you crank it next time see if your ignitor is getting any power from the ecu and power coming out of the ignitor
blownmotor is offline   Reply With Quote
Old 02-24-2008, 08:17 PM   #23
WISH ONE
... make sure you really check everything, i had 3 nissan master techs a stuck on why mine wasnt starting, they all looked right past the cas issue. good luck with the comp issue
Old 02-24-2008, 09:38 PM   #24
OfourTHREEfive
OfourTHREEfive is making a name for him/her selfOfourTHREEfive is making a name for him/her self
Any update on the status, I hate unfinished stories
OfourTHREEfive is offline   Reply With Quote
Old 02-24-2008, 10:26 PM   #25
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
Yep... check compression buddy...
Chrischeezer is offline   Reply With Quote
Old 02-24-2008, 10:29 PM   #26
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
You know the cas has to be set on a specific tooth right?
If it is off the car wont run.
blu808 is offline   Reply With Quote
Old 02-25-2008, 10:16 PM   #27
mxsx25
mxsx25's Avatar
cas and/or igniter... had the same problem... swapped em and started right up
Old 02-25-2008, 10:25 PM   #28
blu808
blu808's Avatar
good going man. Hows it run?
Old 02-25-2008, 10:50 PM   #29
landins13
landins13's Avatar
the car still isn't running, ive gotten kinda side tracked with my 280z. I need to check the compression still, as well as the coils, ignitor is good, im getting fuel, the CAS is in the proper location according to my FSM the only things left that i can think of are the coils and the compression, i made the mistake of loaning a friend my multimeter so i need to get that back. Until then there wont be any updates, i mean in the time ive been waiting on things i lowered the car, started measuring and fabricating my cage, i got my hands on a set of Hayashi racing wheels from the 70's they are the ugliest things ever but i love them lol, they are only 14's but they weigh less than 10 lbs each the fronts are 14x7 +13 offset and the rear are 14x9 +22 offset, they should look obnoxiously good with some drag radials on them
Old 02-25-2008, 10:53 PM   #30
landins13
landins13's Avatar
i didnt see the question about the ignitor until just now, sorry, im running a z32 ignitor and it is brand new, i got ignorant special ordered it from advance auto parts, swapped it with the one i had and returned that one and told them it was the wrong part and got them to refund me.
im real close with the manager and thats what he told me to do so its w/e, lol i spend so much time at advance that i have a commercial account with them.
