Old 02-24-2008, 01:45 PM   #1
4bangers
4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices
CEL help!!
so I got a cel couple days ago and today I went to Schuck to borrow a diagnostic tool. However, they only have OBD-II connection so I couldn't fit into the plug behind the fuse cover, I just found out that that plug is for Nissan Consult, so where do I borrow/rent a nissan consult tool?
I think my s14 is OBD-I so the plug is under the glove box right? where can I borrow a OBD-I tool? thanks all please help.
4bangers is offline   Reply With Quote
Old 02-24-2008, 01:52 PM   #2
d r i f t swift
d r i f t swift's Avatar
d r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the rough
you dont need a tool to pull/ read codes if thats what youre thinking. all you need to do is pull your ecu out from the kick panel and read the blinking leds. search.
rip bobby.. you will be missed..
d r i f t swift is offline   Reply With Quote
Old 02-24-2008, 01:53 PM   #3
juls213
juls213 is making a name for him/her selfjuls213 is making a name for him/her selfjuls213 is making a name for him/her self
What kind of 240sx is it? s13 or s14? If its s14 you are in luck because they have OBDII connectors and colsult port. The OBDII Port is located in the right side of the center console, right next to the radio. If its an s13 you will need a consult or you can get codes by using the ecu, there is a post about this. GOOD LUCK
juls213 is offline   Reply With Quote
Old 02-24-2008, 02:05 PM   #4
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
its a obd1 s14!
read! hah
importdude is offline   Reply With Quote
Old 02-24-2008, 02:12 PM   #5
juls213
Originally Posted by importdude View Post
its a obd1 s14!
read! hah
WOW, I am nissan and infiniti tech and I know my sh**T!
A 95 240sx is a crossover year, that means the vehicle was obdI but with a OBDI and OBDII port. The car is not completely OBDII. The OBDII port is located in the right side of the console. Please CHECK!!
Old 02-24-2008, 06:36 PM   #6
4bangers
yeah, I found the OBD-II port on the right side under the glove box, I borrow Schuck tool and run system check but the tool only do OBD-II. So after the test, the tool gave me code P0705 and a bunch of system is not supported so I don't know what does P0705 is and if it's a right code at all because mine is OBD-I . So where can I get a OBD-I tester or a consult tool? thanks
Also, Juls213, does nissan dealership read codes for free? thanks
Old 02-24-2008, 06:53 PM   #7
S14DB
AFC #1
S14DB's Avatar
You have an Auto Tranny? The Gear sector switch on the side of the tranny is not reporting the gear.
Old 02-24-2008, 08:54 PM   #8
4bangers
no, I have a manual tranny. What? so the code is saying my gear sector is faulty when I don't have an auto?
Although, I don't think mine is a tranny conversion, how do check?
If it is a conversion, how come it didn't throw the code before until now?
Old 02-24-2008, 09:20 PM   #9
S14DB
AFC #1
S14DB's Avatar
Look to see what Tranny is listed on the firewall. Pop off the panel and see what ECU you have.
Old 02-24-2008, 09:35 PM   #10
4bangers
so on the firewall, it will say whether I should have auto or manual?
also, what number on the ecu is for manual and what number is for auto?
thanks
Old 02-25-2008, 01:11 AM   #11
S14DB
AFC #1
S14DB's Avatar
On the pass side firewall it will have your VIN then
Engine: KA24(DE)
Trans: RE4R01A
Old 02-25-2008, 09:12 AM   #12
4bangers
so if the trans is RE4R01A is that auto? what is the code for manual?
Old 02-25-2008, 05:13 PM   #13
redZENKI
redZENKI's Avatar
redZENKI is making a name for him/her selfredZENKI is making a name for him/her selfredZENKI is making a name for him/her self
related info that should help you out
http://www.zilvia.net/f/showthread.php?t=176527
redZENKI is offline   Reply With Quote
Old 02-26-2008, 02:15 AM   #14
4bangers
so today I went and check under my hood. on the trans, it's not RE4R01A so I assume it's not auto from factory. So how come I get this cel about some auto sensor? how do I fix this?
Old 02-26-2008, 07:17 PM   #15
4bangers
is this code for the tranny a manual? FS5W71C RC40
Old 02-26-2008, 07:55 PM   #16
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
Damn, someone in WA help this 9yr old out!!!!
Try this...
http://www.troublecodes.net/Nissan/
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 02-26-2008, 08:36 PM   #17
S14DB
AFC #1
S14DB's Avatar
Goto the dealership, they should pull the consult codes for free.
