Old 01-24-2003, 08:09 PM   #1
N1ceDrgn
N1ceDrgn's Avatar
N1ceDrgn is an unknown quantity at this point
Send a message via MSN to N1ceDrgn Send a message via Yahoo to N1ceDrgn
Question To pack or not to pack...
This may sound strange, but starting with the input shaft bearing and working your way around, the three larger, visible bearings, do they need to be packed before closing up the transmission after disassembling it or not? I've seen different bearings for the different transmissions for my driveline and I checked out the FSM but it mentions nothing about packing them. It looks as if they should be, but I have not seen any information that says to. Does anyone have any information they can pass on?
..working on something that is slowly getting built up and restored..
N1ceDrgn is offline   Reply With Quote
Old 01-24-2003, 08:49 PM   #2
DSC
New Title
DSC is an unknown quantity at this point
Obviously bad things can happen if you don't pack a bearing that should be but what happens if you pack a bearing that wasn't meant to be packed?
DSC is offline   Reply With Quote
Old 01-25-2003, 01:09 AM   #3
N1ceDrgn
N1ceDrgn's Avatar
That's my whole point. I wanted to ask to see if anyone knew anything and had any advice. I am opening it back up tomorrow and I will be definitely going over things to check. It has been two weeks since I had things open. There has been only minimal driving, so I should see a little something, hopefully nothing at all. Well, if anyone does know whether or not the bearings inside and or attached to the transmission core should be packed, please let me know.
Old 01-25-2003, 06:40 AM   #4
bbp
bbp's Avatar
bbp is an unknown quantity at this point
If the bearing is on the inner side of the oil seal, i don't think there is a need to pack it. It should be coated in gear oil when the tranny is filled.
bbp is offline   Reply With Quote
Old 01-25-2003, 07:50 AM   #5
mrmephistopheles
mrmephistopheles's Avatar
Nope. We rebuilt an Xterra tranny at work, and we did no packing of the bearings.
Old 01-25-2003, 08:14 AM   #6
N1ceDrgn
N1ceDrgn's Avatar
Thanks Mephisto.. when you finish work today, swing by.. you know where I'm gonna be all day.. Once again, thanks for the information.
Old 01-25-2003, 09:22 PM   #7
N1ceDrgn
N1ceDrgn's Avatar
As I was right, it was the input shaft seal or I should say, lack there of. When I pulled it, all that was left was the metal casing for the seal. That's all that was left. I also pulled it and resealed everything. So far.. no drips.. I hope it stays that way too..
Old 01-26-2003, 11:53 PM   #8
mrmephistopheles
Good deal. Glad to hear it's fixed. Sorry I couldn't swing by. My 89 is still throwing a code.
Old 07-27-2006, 01:07 PM   #9
Shawn_of_the_Dead
Shawn_of_the_Dead's Avatar
Shawn_of_the_Dead is on a distinguished road
I know this is old and I revived it, but this is the closest topic I could find to my question.
I am assuming that you do not need to pack the diff bearings, however my neighbor with his STi says that they are supposed to be packed and then put in gear oil...sounds weird to me though. Do you need to do both or just put it together and put gear oil in it only? I searched, but nothing answered my question so thanks in advance for any help.
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Shawn_of_the_Dead is offline   Reply With Quote
