Old 02-27-2008, 09:49 PM   #1
megamanx057
megamanx057 is making his/her stupidity well-knownmegamanx057 is making his/her stupidity well-knownmegamanx057 is making his/her stupidity well-known
S14 sr20det transmission - need HELP!
I noticed that on the sr20det transmission there are a couple of connectors. After some research online i've come to the conclusion that they are speed and tach signals. my swap didnt come with anything to connect to the transmission. I do have the lower harness, the one that connects to the fuse box in the engine bay. WHAT DO I DO?
megamanx057 is offline   Reply With Quote
Old 02-28-2008, 07:43 AM   #2
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
what i did is i just plugged in the speed sensor on my ka lower harness but since the sr speed sensor reads for kilometers, you need to use the ka 5spd speed sensor for it to read correctly(mph) ...the other wires you can clip off or tuck away(i just tucked mine away)...the only other sensor you even need thats if u even care about it would be your reverse lights.
hope this helps
ecuastyle84 is offline   Reply With Quote
Old 02-28-2008, 10:42 AM   #3
megamanx057
thanks for the help
