Old 03-05-2008, 09:03 PM   #1
RMJmotor
RMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud ofRMJmotor has much to be proud of
Send a message via AIM to RMJmotor Send a message via Yahoo to RMJmotor
FS: RMJ - 1989 240sx Fully Built Drift Car
This is a race car and has no smog and is not smog legal in California, we are selling this car as is and will not be responsible for smog.
Last Dyno was on 2-10-2008, car made 302whp at 13.5 psi
All work and maintenance done strictly by RMJ. Tuning by Illicit Performance, Machine work by Indio Motor and Machine
Sr20DET
-Balanced and micropolished crankshaft
-Cryo treated stock rods
-MAHLE pistons & Rings (8.5.1 compression) (86.5mm bore)
-Head Port and Polished by Illicit Performance
-Cometic Head Gasket
-Jim Wolf Valve guides
-OEM Nissan Valve Seals
-Head hot tanked, pressure checked, and valve job done (Indio Motor and Machine)
-Brian Crower Valve springs and retainers
-Brian Crower 264 Cams
-Engine has gotten an oil change before every event, 10-40 Neo Synthetic
-Engine was built end of 2006 and ran in the 2007 Top Drift Series
-Head is new and built in January 2008
Turbo Performance Built: T3/T4 Turbo .70ar Hot Side
Turbo Performance Intercooler
Intercooler and Exhaust Piping Custom
Taka Motorsports Oil Feed Lines
GReddy Type R Blow off Valve
Engine Management: Haltech E6X
-LS1 Coil ignition
-3-bar Map sensor
-Tuned by Illicit Performance
650cc Fuel Injectors
NISMO Fuel Pressure Regulator
Rotary Performance, Denso Racing intake Fuel Pump
Stock SR20 Transmission, serviced with only Neo Synthetic Oil every two events
KAAZ 2-way LSD, serviced with NEO Synthetic Oil after every event.
Water pump is 1 year old
KOYO Radiator 2 years old
New Nissan Thermostat (installed 2-20-08)
-Engine has only been ran on Distilled Water and NEO Synthetic Keep Cool
Stock Crank Fan
17" Electric Fan
B&M Oil Cooler with Taka Motorsports Oil Filter Relocation kit and lines
Chassis/Suspension
-TEIN HE Coilovers (no leaks, work great)
-Battle Version Front Tension Rods
-TEIN Tie Rods and Ends
-Rack and Pinion 2-years old
-Battle Version Rear upper control arms
-Urethane Sway bar end links
-Tanabe front sway bar
-Wrong Way SPL 6-point cage (PRO AM Legal) Built by Henry Schelley
INterior
-GReddy 52mm Oil Pressure Gauge
-GReddy 52mm Boost Gauge
-GReddy 60mm Warning Water Temp Gauge
-GReddy 60mm Warning EGT Gauge
-GReddy Turbo Timer
-Apex AVC-R Boost Controller
-Sparco Bucket w/Bride Seat Rails (drivers, passenger seat is stock)
-Momo Steering wheel
-Interior is stripped
-Battery relocated to rear, behind passenger seat
Exterior
-VIS Hood
-Type X Tails lights and garnish (with key and lock, installed brand new 3 years ago, no damage)
-30mm Rear Fenders
-Nismo Front
-Vertex Replica Side Skirts
-Type X wing
-Four Falken Hannabi wheels 17x9 20offset
-Brakes: (installed mid 2007)
Front Project Mu Titan Kai Pads w/ Power Slot Rotors
Rear: Stock Rotors with Hawk HP Plus Pads
Car runs Solid and has a lot of history and references, just ask around the JustDrift and Drift Day community.
Just finished a strong performance in Top Drift Round 1. Has finished top 8 in Top Drift in 2007, performed at the Pro AM Nationals in November 2007. We are selling the car because we are focusing on our drivers 240sx coupe.
These are all current photos and the video is from the last event on 2-24-08
If you have any questions or want to see the car, please feel free to contact me.
$15,500
Miguel - RMJ Motorsports 805-340-6353
Video: http://rmjmotorsports.com/gallery/Im...d1_2008rmj.wmv
Performance - Tech Support - rmjmotorsports.com
RMJmotor is offline   Reply With Quote
Old 03-05-2008, 09:23 PM   #2
whatjohnboy
whatjohnboy is making his/her stupidity well-knownwhatjohnboy is making his/her stupidity well-knownwhatjohnboy is making his/her stupidity well-knownwhatjohnboy is making his/her stupidity well-known
14g's for a DRIFT READY car??!! not bad AT ALL!! love the wing! glws bro.
whatjohnboy is offline   Reply With Quote
Old 03-05-2008, 11:11 PM   #3
khmerguy618
khmerguy618's Avatar
khmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfection
Send a message via AIM to khmerguy618
Seen this car in person at JD last season, it's frickin ill. GLWS
Watch speed channel 12/9 @7.30PM for drifting at HIN!
[email protected]
IF you bought stuff from me write me a review HERE
||VEXMOTORSPORTS || DMAX-USA || RPS CLUTCH || BAB AUTOBODY||
khmerguy618 is offline   Reply With Quote
Old 03-05-2008, 11:23 PM   #4
RMJmotor
Thanks for the comments guys
Old 03-05-2008, 11:24 PM   #5
Dousan_PG
Dousan_PG's Avatar
what why!
oh i c i c
car runs fantastic!
good luck miguel!
Aaron
Pink GodziRa
Old 03-05-2008, 11:27 PM   #6
panama DRIFT
panama DRIFT's Avatar
panama DRIFT is an unknown quantity at this point
Send a message via AIM to panama DRIFT
miguel WHY???? g/l on sale bro
panama DRIFT is offline   Reply With Quote
Old 03-06-2008, 07:31 AM   #7
RMJmotor
ya mr. dousan, we will still be out there running, should have the coupe ready for round 2
Old 03-07-2008, 11:16 AM   #8
s13coupe805
s13coupe805 will become famous soon enoughs13coupe805 will become famous soon enoughs13coupe805 will become famous soon enoughs13coupe805 will become famous soon enoughs13coupe805 will become famous soon enough
bump for an awesome car, hey miguel when you want me to come by and chill again lol.
s13coupe805 is offline   Reply With Quote
Old 03-07-2008, 11:31 AM   #9
Kenji001
Kenji001 is making a name for him/her selfKenji001 is making a name for him/her selfKenji001 is making a name for him/her self
nice car....bump
Kenji001 is offline   Reply With Quote
Old 03-16-2008, 04:42 PM   #10
RMJmotor
No one interested in her? there is over 30K into this car, i have all the reciepts, lol, turn key and ready to rock
Old 03-20-2008, 12:05 PM   #11
RMJmotor
Price drop to $14,500. need to make room in the shop. Haltech powered, ls1 coils, low boost 302 whp and capable of much more with bigger injectors and tuning.
It performs like a champ and is a well known vehicle with JustDrift
Old 03-22-2008, 10:36 PM   #12
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
i saw this car at justdrift..freakin sick car!!
Slammed Assassin is offline   Reply With Quote
Old 03-23-2008, 09:55 AM   #13
RMJmotor
would make a sweet Easter gift, lol hint hint
Old 04-13-2008, 10:51 PM   #14
RMJmotor
Bump, will make a final appearance at Top Drift Round 2, Horse Thief mile
Old 04-14-2008, 03:57 PM   #15
mrduece88
mrduece88's Avatar
mrduece88 is making a name for him/her selfmrduece88 is making a name for him/her self
I'll give you $10
Illicit Performance
mrduece88 is offline   Reply With Quote
Old 04-14-2008, 04:29 PM   #16
RMJmotor
You PAN you meen 10 pesos
Old 04-14-2008, 10:34 PM   #17
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
BUMP dope ass car wanna sell the kaaz to me??
and i gave sam neg rep lol
Red Rocket
apex is offline   Reply With Quote
Old 05-27-2008, 10:47 PM   #18
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
dude you should wait and make sure the coupe is set and Jason likes it because if he doesn't he should sell the coupe and buy your hatch from you. you feeling me bro
s13 @ fullboost is offline   Reply With Quote
Old 05-28-2008, 02:51 PM   #19
EhBambino
EhBambino is making his/her stupidity well-knownEhBambino is making his/her stupidity well-knownEhBambino is making his/her stupidity well-knownEhBambino is making his/her stupidity well-knownEhBambino is making his/her stupidity well-known
Those are Nismo Replica sideskirts
looks noice
EhBambino is offline   Reply With Quote
