Old 02-01-2003, 09:02 AM   #1
ngk1053
ngk1053 is an unknown quantity at this point
need more help fixing smelly tranny
What's up everybody, I'm pretty new to Zilvia but I found it to be an awesome source for info. I've read all the old threads on shift boot smoking and the smell of transmission fluid and am in the process of fixing the problem. I took off the crappy vinyl boot, then the big rubber one underneath, and sure enough the last 3rd boot was torn. So I pulled it off, but the problem is I don't know how to get the new one on. The hole at the top is too small to slip over the shifter (I removed the knob). It looks as if you could probably twist that black shifter cover off of the bare steel shifter which runs all the way down to the tranny, but it won't budge. I tried vise grips just like with the knob and it seems as if I'm going to break the shifter if I twist anymore. Does anyone know if you can take it off or how to get that little rubber boot on the bottom? Thanks
-Nick
ngk1053 is offline   Reply With Quote
Old 02-02-2003, 08:20 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
Vaseline or K-Y. Once you've removed your shift knob, you slide the boot down the shifter. It's a pain, but that's the way to do it.
-Kevin
Old 02-02-2003, 10:02 AM   #3
ngk1053
You know I actually already thought of that, but thought it might be a little weird to combine KY and cars...but oh well I'll give it a shot, as long as it works right...Thanks for the help
-Nick
