Old 03-19-2008, 11:26 PM   #1
MrBones
MrBones is an unknown quantity at this point
s13 Problems
Ok so I'm looking at an s13 an heres the crap I can kinda tell that is wrong, but could be others, looking for some insight
water/steering belt needs to be tightened (car heats up to high but then returns to normal, I assume the belt isnt gripping the water pump enough)
rough idle - TPS?
cant get above 2500 rpm - was told that was MAFS
thick black smoke out the rear end (smells like gas) - was told could be a couple things - bad plugs/injectors/ or even worse, needs engine rebuild for new piston rings/lose of compression
engine has 196,000 miles on it, which iv been informed is a sh*t ton for 240's
engine rebuild time? (i'd rather not be without a car for 2 weeks)
MrBones is offline   Reply With Quote
Old 03-19-2008, 11:33 PM   #2
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
maybe the waterpump is already shot. i wouldnt recommend buying it for starter. but if you are ready to put money into it. go for it
Old 03-19-2008, 11:36 PM   #3
Sileighty_85
Sileighty_85's Avatar
Thats definalty a Project Car, Plan on rebuilding that engine
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-20-2008, 01:28 AM   #4
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
definite rebuild
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
