Old 03-20-2008, 10:19 PM   #1
NismoLmgt4
NismoLmgt4 is a well-known jackass
tire sizing for a 18x10 18x9
i have Work meister s1 3pc the fronts are 18x9 and rears 18x10. I dont want that stretch look i want the rear to have a bit of a buldge look and the fronts to line up perfect with the wheels. So do you guys reccemond a 265/35 in the rear and a 245/45 in the front?
NismoLmgt4 is offline   Reply With Quote
Old 03-20-2008, 10:23 PM   #2
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
S14 i'm assuming????? Stock bodywork....Overfenders.....roll....pull....???? NEED MORE INFO!
96Turbo is offline   Reply With Quote
Old 03-20-2008, 10:34 PM   #3
NismoLmgt4
S13 getting wheels mounted and balanced then going to get them pulled and rolled to fit perfectly
Old 03-20-2008, 10:38 PM   #4
advan_s13
advan_s13 is an unknown quantity at this point
I have 5Zigen Pro Gn+ 18x10 in the rears and run a 245 wide, stretched a lil. a 265 would be straight, 275 bulged. I have my fenders rolled and stretched and it all works well.
s13 sr20det Full JIC suspension HKS HiPower 5Zigen Pro GN+
advan_s13 is offline   Reply With Quote
Old 03-20-2008, 10:41 PM   #5
NismoLmgt4
so the front i would be looking at a 255/45? and the rear a 275/35? cause i want the front to be straight dont want that stretch look
Old 03-20-2008, 10:42 PM   #6
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
GO DO SOME RESEARCH.
Theres a WHEEL FITMENT WHORE thread as well.
My iTrader rating!
babowc is offline   Reply With Quote
Old 03-20-2008, 10:43 PM   #7
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
If you want the square look up front go with a 245 or 255 width.
The rears will need a 275 or 285 to be near square. If you want the BULGE look go with a 305 or 315. However, that large of a rear tire with only a 245 or 255 up front is just retared. Id stick with the 275 unless drag racing.
Keep in mind i have no regard to what type of body work you will be doing. I'm simply answering your question based on rim size, not body clearance.
EDIT= FUCK NO to a 255/45/18 front. A 255/35/18 is more like it.
gotta240 is offline   Reply With Quote
Old 03-21-2008, 12:48 AM   #8
Jlee
Jlee is a jewel in the roughJlee is a jewel in the roughJlee is a jewel in the roughJlee is a jewel in the roughJlee is a jewel in the roughJlee is a jewel in the roughJlee is a jewel in the rough
i'm running 18x9 front 225/40/18 and 18x10 rear 255/40/18 and it's a light stretch.
pics of fronts...
rears tires will be mounted soon..
Jon
Jlee is offline   Reply With Quote
Old 03-21-2008, 12:51 AM   #9
JeremyR
JeremyR's Avatar
JeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the rough
Send a message via AIM to JeremyR
245/40/18 and 265/40/18
JeremyR is offline   Reply With Quote
Old 03-21-2008, 01:01 AM   #10
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
^^^^ that looks about right.
TEAM SUS*PECT
Old 03-21-2008, 01:11 AM   #11
gotta240
Negative on the 265/40/18.
You'll want a 35 series sidewall for that width tire. Dont forget, just cause the middle number is the same, doesn't mean the height is the same or even close to being the same.
Old 03-21-2008, 01:19 AM   #12
ALEXTHESUS*PECT
but he wants a bulge and that will give him one.
TEAM SUS*PECT
Old 03-21-2008, 02:27 AM   #13
kornaz
kornaz's Avatar
kornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfection
Send a message via AIM to kornaz Send a message via Yahoo to kornaz
Look out for potholes with that 35 series tire. I run a 225 on a 10 wide wheel. Thinking about going 45 next. Too many potholes/fucked up roads after rainy season.
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fucking temperamental.
kornaz is offline   Reply With Quote
Old 03-21-2008, 04:24 AM   #14
JeremyR
JeremyR's Avatar
a 35 series tire is going to be too small for this guy, he wants a straight front, slight bulge rear. a 265/40/18 is what he needs for the rear. the sizes i listed are correct.
the series 35, 40, 45, etc is the percentage of sidewall to tire width "35% of 255, 40% of 265"
Old 03-21-2008, 05:27 AM   #15
NI_YON_Zenki
NI_YON_Zenki's Avatar
NI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud of
Meister Tire!
Meisters, Good, but typical choice!
265/35 rear, depending on how much you drive & where, you may want a 40 for tread (traveling) meat, 35's for look/stylsh setup, which is still very cool. I am running Goodyear Eagle F1 235/35/18 @ -20 rear wheel, so I have a slight stretch, due to poor fender pull (its just the paint really)
BUT. .. .
45 up front; way unbalanced for the 35 option(s) in the rear, go for a relative size match, 45/40 - 40/35 - 35/30
35/40 265 rear, 235-OR-45 up front. IMO.
Let me see the wheels, you have tires now?
"GHOST"
NI_YON_Zenki is offline   Reply With Quote
Old 03-21-2008, 05:35 AM   #16
a_ahmed
a_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfection
Originally Posted by w00tang View Post
195/10/18
If you want to rice it up and stretch it like a hoe go to the extreme stretch thread. If you want to ACTUALLY utilize your wheel and fit 275 or 285 rubber go to the maximum rubber and wheel fitment thread.
I plan to run 18x10.5 with 285/30/18 up front on mine... so
maximum rubber wheel fitment thread:
http://www.zilvia.net/f/showthread.php?t=166563
extreme stretch (imho modern rwd ricer thread if you want to run a 195 on it lmao):
http://www.zilvia.net/f/showthread.php?t=136032
Make up your choice
a_ahmed is offline   Reply With Quote
Old 03-21-2008, 05:48 AM   #17
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
Originally Posted by a_ahmed View Post
blah blah blah
jesus you might as well just own a camaro
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 03-21-2008, 05:51 AM   #18
a_ahmed
jOwn a camaro? Wow so big tires are for camaros!! Genius! Im sure based upon that all race teams should start getting camaros from now on!
And if you blabla back. Why f'en get a 18x100000 rims if you don't fucken use the wheel, waste of money, extra weight, ridiculous, rice, scrapped rim lip (bye bye rim), etc... so stupid...
Oh wait let me get my Formula 1 camaro. Actually you should have at least said something more educated like why don't you get a corvette? Because I can't afford one. It's a better vehicle than any nissan car ever made to the exception of highly modified 300zx and skylines. Don't believe all you read in sportscompact magazines. Yes yes, v8s are heavy, the good ol bullshit, the new corvette can eat skylines for lunch, and I love skylines. Guess what, it has big rubber, big v8, its all modern, not the stereotype of "oh those cars are heavy, they cant handle uuh big v8 booga booga". Misinformed.
Either you want your car to go fast or to look cool for mtv yo yo kids not realizing how stupid it actually is.
If anything, stretching your tires over gigantic wheels will help you f up your rim over potholes.
Old 03-21-2008, 06:31 AM   #19
OBEEWON
OBEEWON's Avatar
Depending on what brand tire you run, but mostly a 265 on a 10 will not bulge at all, especially with a 35.
I suggest 285 for a bulge. 275 will be square. But again it depends on the brand of tire you go with.
Old 03-21-2008, 07:07 AM   #20
olah.inc
olah.inc's Avatar
olah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enough
i throw a question into this: what size for a nice stretch? 215/40 front and 245/35 rear?
olah.inc is offline   Reply With Quote
Old 03-21-2008, 07:18 AM   #21
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
205 or 215 fronts
and 225 rears
that would looks pretty good. theres crazier shit, but i think this is generally safe for the most part
im not sure of the sidewall cuz i dont rock 18s and im too lazy to go on a tire size calculator
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 03-21-2008, 07:20 AM   #22
spanishricer
spanishricer's Avatar
spanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfectionspanishricer is close to perfection
These are 275/35/18 Kumho MX's on an 18x10 wheel.
Tire choice also plays a key factor on how they fit the wheel. Two pairs of tires may have the same size written on the sidewall, but fit differently based on the design of the tread/sidewall.
spanishricer is offline   Reply With Quote
Old 03-21-2008, 07:57 AM   #23
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Im with him...to get it close to stock diameter, youll have to kick down the side wall. Personally, I'd run 235/40 front and 265/35.
CLICK HERE!!!
Old 03-21-2008, 08:29 AM   #24
usdm180sx
usdm180sx's Avatar
Way to go by not posting the offsets
-Norm!
Old 03-21-2008, 09:09 AM   #25
fliprayzin240sx
Way to go by not reading what he's trying to do!!!
Go read the thread before you start bitching...he's gonna pull the fenders to fit whatever shit he throws in it.
CLICK HERE!!!
Old 03-21-2008, 10:03 AM   #26
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Blah blah blah
Dude, seriously, it's not necessary to bad mouth other peoples shit whenever you get the chance, throwing a jab at stretched tires at every opportunity is childish and stupid.
I don't give a shit if you like it or not, it's just annoying to see you posted and it's going to be another garbage post.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 03-21-2008, 10:07 AM   #27
usdm180sx
usdm180sx's Avatar
You can only pull so far. A starting reference point would help?
-Norm!
Old 03-21-2008, 10:35 AM   #28
Ian
blah blah blah again
actually i said you might as well own a camaro because i was pretty sure you couldn't afford a better domestic.
and yeah, i wouldn't know anything about corvettes because there definitely isn't one sitting in my driveway...
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
No it isn't
Old 03-21-2008, 10:45 AM   #29
WISH ONE
ive got 255 45 17 bridgestones 17x9 bbs on my 13 coupe in the rear and its just about square with the wheel my fenders are pulled not wildly but enough
