Old 03-24-2008, 10:56 AM   #1
thewhiteknight
thewhiteknight's Avatar
thewhiteknight has made poor choicesthewhiteknight has made poor choicesthewhiteknight has made poor choicesthewhiteknight has made poor choicesthewhiteknight has made poor choicesthewhiteknight has made poor choices
timing question....
alright i know im probably going to get banned for this, but i CANNOT find the answer to this with all the searching ive done.
i dont have the means to get access to my crankshaft sprocket to see the mating mark to the gold link on the timing chain. with that being said i am trying to figure out what position my cams should be at without using the silver links as a reference. im pretty sure that the gold link slipped past a few teeth when i was replacing my headgasket or this wouldnt be an issue. if i put #1 piston at tdc what position do my cam need to be in for correct timing?? any help is greatly appreciated.
__________
lima bean on the hang down
thewhiteknight is offline   Reply With Quote
Old 03-24-2008, 11:03 AM   #2
serturbo
serturbo is an unknown quantity at this point
Can it jump? On my engine, there are guard pins on the front cover. They don't allow the chain to move far enough from the gear to jump.
serturbo is offline   Reply With Quote
Old 03-24-2008, 11:20 AM   #3
thewhiteknight
well the only reason i suspect this is because i accidently dropped the chain while replacing the hg, and when i tried to set the timing back the normal way ( put the piston at tdc and line the silver links up on the dots on the cam gears) it didnt work.
__________
Old 03-24-2008, 11:22 AM   #4
boogerlovers
boogerlovers's Avatar
boogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond repute
your intake cam should be at 10:00 and your exhaust cam should be at 1:00...after they are set as close to those positions as possible count the rollers(silver dots) in between the markings on you cams...there should be 20...and remember the lobes on the cams should be facing outwards...
boogerlovers is offline   Reply With Quote
Old 03-24-2008, 11:33 AM   #5
thewhiteknight
i found this picture... is it correct?
__________
Old 03-24-2008, 11:35 AM   #6
boogerlovers
yeah that looks about right... good luck with your timming
Old 03-24-2008, 03:16 PM   #7
steve shadows
steve shadows's Avatar
You can also use the Crank pulley's marking to detinguish tdc, then count 21 links(pins) between the two dots (as in the pins on the links).
Like Me on FaceBook !
Old 04-01-2008, 05:56 PM   #8
thewhiteknight
thanks!
yea i figured it out.... thanks boogerlovers. i also had an issue with my cas... easily corrected though.
__________
