Old 03-28-2008, 04:26 PM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Early JDM climate control vs digital climate control (s-13)
I am doing a ca18 swap for my buddy and his clip came with the early (non-digital) climate control. I want to put the climate control in his fastback, but I wanna use a digital unit. Does the wiring and sensors crossover directly from the early climate control to the digital one or do I need a new harness? I have all the harnesses and the control unit for the early climate control, I have found a DCC control unit for really cheap, and I have found plenty of write-ups on the DCC install so I just need to know if the wiring and sensors would crossover from the early one to the DCC unit.
Old 03-28-2008, 04:31 PM   #2
NemeGuero
No more nissan.
NemeGuero's Avatar
I think that there are sensors involved with the digital climate control that don't exist on the older ones.. such as in-cabin temp and a few others.
doesn't the write-up detail what you need?
Old 03-28-2008, 04:54 PM   #3
Ragnarok043
Ragnarok043 is making a name for him/her selfRagnarok043 is making a name for him/her self
you definitely need the DCC harness, it converts the standard harness to the DCC and it has the connectors for the additional sensors such as the sun load sensor, cabin temp sensor and the air mix motor.
Ragnarok043 is offline   Reply With Quote
Old 03-28-2008, 04:55 PM   #4
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
Start pulling your buddies clip apart looking for all the appropriate sensors, there is a list in all the FAQ's I found on the net. If you are missing sensors try contacting Kaizouten at:
[email protected]
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 03-28-2008, 05:03 PM   #5
Om1kron
Om1kron's Avatar
I read the faq for that and I think I like the analog just fine lol. Granted the digital would be cool it's a whole lot of work and old wires to fiddle with.
Wayne Edwards
https://om1kron.blogspot.com
Old 03-28-2008, 05:03 PM   #6
racepar1
racepar1's Avatar
It has the sunload sensor and the vent temp sensor that mounts in the little tube for sure.
EDIT: I just checked the write-up and it appears that all the necessary sensors and parts are there. Will it plug in though? Do all the sensors operate the same? I would think so but I would like an experienced opinion.
Old 03-28-2008, 05:18 PM   #7
Om1kron
Om1kron's Avatar
Not a lot of people here have done the conversion from what I've searched, I think your best bet is hitting up the member "broadway" i think it is, he has the conversion done in his car and probably could best tell you from "experience"
Wayne Edwards
Old 03-28-2008, 07:31 PM   #8
rongfk
rongfk's Avatar
rongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond repute
i got what you need. take a look.
http://www.zilvia.net/f/showthread.php?t=173392
you can find the digital units from 25-50 bucks. so all you need is the unit, sub-harness, and some of the things that i have. you already have the rest.
for sale: http://www.zilvia.net/f/showthread.php?t=193169
-1990 s13 hb w/all jdm 180sx goodies... gone to fresno
-1985 ae86 gts turbo... going threw a heart transplant
-1963 euro ragtop bug... asleep in the garage
Luv 2 Build, Luv 2 Show, Luv 2 Cruise!....
rongfk is offline   Reply With Quote
Old 03-28-2008, 09:56 PM   #9
racepar1
racepar1's Avatar
I have all that stuff from the analog climate control that came in the clip! I already found a digital control unit for cheap as well. What I do need is knowledge on weather or not everything that I DO have crosses over to the digital unit. I would assume that nissan would use all the same stuff in order to cut costs, I just wanna be sure. The way this is going I think I'll just buy the unit and try it.
Old 03-29-2008, 05:15 AM   #10
Ragnarok043
in that case if the connector fits the DCC unit, then you should be fine. just make sure you have all the correct sensors and connectors to plug them into. for me the hardest part was installing the linkage arm to the air mix door, mounting the air mix motor and chopping the blower speed sensor fins.
Old 03-29-2008, 12:18 PM   #11
racepar1
racepar1's Avatar
^^^ Ya i saw that I would have to build a bracket, but that is no biggie. The unit I found has the pigtails, but no sensors and other wiring so I can for sure make it work. Thakns for the replies guys.
Old 04-15-2008, 06:36 AM   #12
tunedbyjdm
tunedbyjdm is an unknown quantity at this point
does your CA18 clip's analog climate control comes with the sun load sensor and airmix motor?
tunedbyjdm is offline   Reply With Quote
Old 04-15-2008, 07:07 AM   #13
Ca_laurier
Ca_laurier's Avatar
Ca_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to all
if its an auto climate control unit all you need to do is hook the digital head on to it. I have done it on 2 silvia's and both of them have worked
just make sure you actually have the whole harness
Ca_laurier is offline   Reply With Quote
Old 04-15-2008, 07:12 AM   #14
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
ok i think i understand your question.
you have a clip that came with one of these (this is what i will be using, i don't care about fancy smancy digital displays)
so you want to know if the harness for this type of control unit will work on the DCC. i've been slowly rewiring mine, and all of the info on the internet seemed to match my harness. if you want i could take pictures or something...PM me if you need something
clark is offline   Reply With Quote
Old 04-15-2008, 11:41 AM   #15
racepar1
racepar1's Avatar
^^^That's exactly it! I have decided to just wing it and go for it. The DCC unit came with the pigtails so even if the non-digital unit's connectors don't match I can still wire it up. And I DID remove the ALL of the A/C wiring from the dash harness so anything I need will be there. I honestly won't get to doing this for a while though.
