Old 03-29-2008, 02:38 PM   #1
n1smo413
n1smo413's Avatar
n1smo413 is on the path to ruinn1smo413 is on the path to ruinn1smo413 is on the path to ruin
Send a message via AIM to n1smo413
bogging issue
Well the other day i put on a intake on my car.After i installed it and drove it it would bog whenever i floored it.I checked all the hoses and made sure everything was on correctly.I put my stock intake back on and everything ran fine.So i thought i could just run the cone filter at the end of the maf.I tried that and it would bog again when i floored it.Put the stock air box back in and it ran fineAnyone know why my car does this?
driftfaction.com
@driftfaction
n1smo413 is offline   Reply With Quote
Old 03-29-2008, 02:50 PM   #2
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
what motor? if the filter is a wet style, it will clog the maf, you need a dry flow filter or a simple metal mesh filter.
landins13 is offline   Reply With Quote
Old 03-29-2008, 03:06 PM   #3
n1smo413
n1smo413's Avatar
is a ka24de.and yes i do have a dry flow filter.I also took a filter off my friends car and it did the same thing
driftfaction.com
@driftfaction
Old 03-29-2008, 04:03 PM   #4
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
Sounds like a vacuum leak after the MAF. Are you sure there are no leaks or unplugged fittings on the new intake?
"Genius may have its limitations,
but stupidity is not similarly handicapped."
Big Bronze Rim is offline   Reply With Quote
Old 03-29-2008, 04:06 PM   #5
n1smo413
n1smo413's Avatar
all the fitting are good.when i take the cone filter out and put the stock airbox back in everything runs fine
driftfaction.com
@driftfaction
Old 03-30-2008, 05:13 PM   #6
n1smo413
n1smo413's Avatar
figured it out.for some reason it was the fuel pump.My car is way faster now to.when i took the old pump out the filter was black.
driftfaction.com
@driftfaction
Old 03-30-2008, 08:38 PM   #7
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
gj on finding the problem. i rep u for actually attempting to solve your own problem.
gl,
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 03-31-2008, 12:10 AM   #8
2,1
2,1's Avatar
2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore2,1 is not welcome here anymore
sometimes you just gotta do it yourself.
2,1 is offline   Reply With Quote
Old 03-31-2008, 12:20 AM   #9
leveloneae86
leveloneae86's Avatar
leveloneae86 is making a name for him/her selfleveloneae86 is making a name for him/her self
so u replaced the fuel pump or u just replaced the filter? i never took a fuel pump out so im just curious if its the same problem for me. thanks
leveloneae86 is offline   Reply With Quote
Old 03-31-2008, 08:03 PM   #10
n1smo413
n1smo413's Avatar
i replaced the fuel pump.I did the filter to awhile ago with a z32 one but the pump was the actual problem.It took about 15 minutes to replace.
driftfaction.com
@driftfaction
Old 03-31-2008, 08:10 PM   #11
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
hmm...i might have to do the same..just like everyone else.. +1 rep to you for getting it fixed
HS13KLS is offline   Reply With Quote
Old 04-01-2008, 09:07 PM   #12
n1smo413
n1smo413's Avatar
thanks for the rep.It was well worth fixing.I almost swapped motors.
driftfaction.com
@driftfaction
