Old 03-31-2008, 10:23 AM   #31
SusanR34
SusanR34's Avatar
SusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to allSusanR34 is a name known to all
Send a message via AIM to SusanR34
Full Kit
Heres a pick of the full kit and install. Its a lot of work, but works great.
-Susan Adrenaline Motorsports Inc. 636-477-9363
www.adrenalinexxx.com [email protected]
SusanR34 is offline   Reply With Quote
Old 03-31-2008, 08:34 PM   #32
McRussellPants
Started working on my car today at 2ish.
Everything on it but the switch panel will be wired by tommorow.
Nissan wiring is total dicks, I hate it.
This painless stuff is easy peasy.
McRussellPants is offline   Reply With Quote
Old 03-31-2008, 09:05 PM   #33
Enjin
Enjin's Avatar
Enjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enough
Send a message via AIM to Enjin Send a message via Yahoo to Enjin
lololol @ easy peasy
this makes me a feel a lot better. painless 8 circuit +1.
does it come with instructions? I've got no problem with wiring/soldering, I just want to know exactly what to do... if not, I can probably figure it out.
1991 Nissan 240sx
www.tractionoptional.com
Enjin is offline   Reply With Quote
Old 03-31-2008, 09:21 PM   #34
McRussellPants
nah, not really.
its very straight forward.
take out all the stock stuff.
put the fuse box where you want it.
send the wires where they need to go, they all have the location printed on them
the alternator needs a switched ignition power so I just used the accessory wire.
I still need to fiddle with the ECU, but I have wiring to do on the PFC before I hook it up.
Old 04-01-2008, 09:36 AM   #35
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
Go on the painless site. They have the kit instructions in PDFs. When you're actually wiring it you barely need to look at the manual. Every wire is labeled(I think every 5") so you just send it to where it says. Simple. Hardest part will be if you're keeping the factory signal stock and ignition. I'm keeping the signal stock, but using a switch panel for ignition.
JVD is offline   Reply With Quote
Old 04-01-2008, 09:49 AM   #36
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Yea, I have a 12 circuit kit sitting in my room, need to throw it in a car one of these days.
Too lazy, and dumb with electronics. I don't want to do the research to get myself smart on it, lol.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
