Old 04-14-2008, 12:08 AM   #1
Maxstyle
Maxstyle's Avatar
Maxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond repute
Nismo 2 Way LSD?
I just got a used nismo 2 lay lsd. Clicks like crazy when i turn LEFT. When I turn right, it' feels fine. Any Ideas?
Maxstyle is offline   Reply With Quote
Old 04-14-2008, 12:09 AM   #2
Dousan_PG
Dousan_PG's Avatar
its used
what did u expect?
probably needs a rebuild.
Aaron
Pink GodziRa
Old 04-14-2008, 12:10 AM   #3
Signum Temporis
Signum Temporis is a well-known jackass
Send a message via AIM to Signum Temporis
Signum Temporis is offline   Reply With Quote
Old 04-14-2008, 12:20 AM   #4
deolio
deolio's Avatar
it seems like mine has always clicked a lot more on the left since it was new now that i think about it...
Old 04-14-2008, 12:26 AM   #5
Maxstyle
Maxstyle's Avatar
who rebuilds these out here? I'm in Socal. HB area
Old 04-14-2008, 12:28 AM   #6
Dousan_PG
Dousan_PG's Avatar
call up justin at WestCo nissan
he should be able to point u in the right direction as well as maybr order the parts up for you.
West Covina Nissan--ask for Justin the parts dept.
205 N Citrus Ave
West Covina CA 91791
JDM and OEM Nissan/Infiniti parts, NISMO, Endless, AME, Enkei, Exedy, Motul oils, Greddy, Apex'i, JP Aero, Vertex and more...
www.thenismoshop.com
626-732-1000
ps: you should have juts bought a new LSD instead of used once since now u might get stuck rebuilding it.
live and learn.
Aaron
Pink GodziRa
Old 04-14-2008, 12:39 AM   #7
theslows13
theslows13 will become famous soon enoughtheslows13 will become famous soon enoughtheslows13 will become famous soon enough
my brand new tomei clicks a little more when i turn (forget which way) more than the other way. possible that it just needs broken in more?
just a little more clicking, not a drastic difference
theslows13 is offline   Reply With Quote
Old 04-14-2008, 12:41 AM   #8
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
my shit clicks like whoa.... esp since i got some solid bushings...... you could always get friction modifier, i hear that works well though i have no exp with that. and i also have a tomei, not a nismo
Old 04-14-2008, 12:49 AM   #9
Maxstyle
Maxstyle's Avatar
Yeah, I have solid subrame bushings too. No ruber on my subrame to give. I know the risk i took. Oh well. i will have to eat the loss no comlaints. Ill give that justin guy a call. We deal with him where i work. He's pretty cool people.
Old 04-14-2008, 01:24 AM   #10
sldbyuramg
sldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant future
so...shouldnt the NISMO 2 way LSD be pretty stout? how often would you need to rebuild it...im looking into an LSD and i wasnt really thinking that a NISMO or say KAAZ would need a rebuild that often unless you were running serious power... idk...
sldbyuramg is offline   Reply With Quote
Old 04-15-2008, 10:55 PM   #11
krazyunos13
krazyunos13 is an unknown quantity at this point
I have a nismo lsd on my s13 and i just wanted to know if its bad that how it clicks everytime when i turn?
krazyunos13 is offline   Reply With Quote
Old 04-16-2008, 11:17 AM   #12
jackjack
jackjack's Avatar
you guys have a clicking problem? weird. my kaaz is super quiet. the tires cherp only when i make slow tight turns.
Old 04-16-2008, 11:54 AM   #13
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Clunking/Clicking whatever you want to call it is completely normal with a clutch type differential.
It really should be making the clicking/clunking in both directions if the turns are the same. If you're talking about making a nice wide left turn vs a short right (because of the way roads are here in America) then it would make sense if it is making different noises.
Go drive in a circle one way, then turn around and go the other, it should sound the same. Does it lock up fine on both left and right hand slides?
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 04-16-2008, 12:00 PM   #14
drifting_changed_mylife
drifting_changed_mylife's Avatar
drifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymore
Send a message via AIM to drifting_changed_mylife
2 words....... your fucked
your neg reps match my avitar.... keep em commin
drifting_changed_mylife is offline   Reply With Quote
