Old 04-13-2008, 12:38 PM   #1
tha240star
tha240star is making a name for him/her selftha240star is making a name for him/her self
SR Why Does My Sr Sound Like A Subaru?
Hi Everyone, Before I Ask For Help Let Me Give U A Background Of What Happened. This Mornin I Finally Figured Out Why My Car Wouldnt Idle, It Was My Electric Fan, It Drained My Battery Cuz I Didn't Have The Thermo Hooked Up.
That Was Solved So I Went For A Little Sunday Drive, Drove Around For Like 6-7 Min Havin A Blast, Then I Go Under Boost 10psi, And All Of A Sudden My Car Turns Into A Wrx ( Not Litteraly). It Started Bucking A Little Bit In The Lower Rpms, Down Shifts Sound Smooth Though. The Idle Sounds Different Also.
I Have A Greddy Interecooler, Hks Ssq Bov, Stock T25, Turbo Xs Manual Boost Controller, Koyo Radiator, Silicone Hoses, Permacool 15" Fan, Sr20det Blacktop, Finished The Swap On The 28 Mar 08. Tryna Give As Much Info As Possible
If Anyone Knows Whats Wrong Please Help.
tha240star is offline   Reply With Quote
Old 04-13-2008, 12:40 PM   #2
boogerlovers
boogerlovers's Avatar
boogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond repute
if it sounds like a sub and surges...you probably have an exhaust side gasket that is blown...check the gaskets around the exhaust manifold, downpipe and the turbo...
boogerlovers is offline   Reply With Quote
Old 04-13-2008, 12:49 PM   #3
tha240star
oh ok would i be able to feel the air by just putting my hand next to the gasket, or would i have to rev it up?
Old 04-13-2008, 12:53 PM   #4
boogerlovers
if you rev...you would be able to hear it, idk about feeling the air though it depends where you are leaking from...good luck
Old 04-13-2008, 12:56 PM   #5
afro88
afro88's Avatar
afro88 is just really niceafro88 is just really niceafro88 is just really niceafro88 is just really niceafro88 is just really niceafro88 is just really niceafro88 is just really niceafro88 is just really niceafro88 is just really nice
Reminds me of the time my ae86 16v was running on 3 cylinders. Sounded like a vq with some crazy cams running at like 400 rpm.
GL man.
Buy my wheels. Nismo LM-gt1's.
afro88 is offline   Reply With Quote
Old 04-13-2008, 01:02 PM   #6
Tops*
Tops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfection
Just sounds like you blew your piping off.
Have you already checked all your couplers for leaks?
Wasn't there a thread JUST like this floating around recently?
MADE IN JAPAN
Tops* is offline   Reply With Quote
Old 04-13-2008, 01:04 PM   #7
boogerlovers
that too...
Old 04-13-2008, 01:08 PM   #8
tha240star
yeah that was the first thing i checked for, but i couldnt find anything wrong. it boost ok, i had it set to 10 and now it like 9 so im not sure. i hope its just something stupid and easy to fix
Old 04-13-2008, 01:18 PM   #9
cotbu
cotbu's Avatar
Disconnect the coil packs ,1 at a time. If there is no change, that's the cylinder. You need to find out if it's a spark or a fuel problem!
OP stop boosting...
Old 04-13-2008, 01:24 PM   #10
astrophixvox
astrophixvox's Avatar
astrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura aboutastrophixvox has a spectacular aura about
If it's a gasket you'll be able to feel the air leak at idle. I have a leak right now and i don't have a rough idle or any problems other that i don't boost my full potential. I agree with cotbu....might be fuel or spark.
astrophixvox is offline   Reply With Quote
Old 04-13-2008, 01:30 PM   #11
tha240star
ur right i removed the last coil pack, and there was no change, now i need to find out if its spark or fuel like u said
Old 04-13-2008, 01:35 PM   #12
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
for spark check coilpacks, ignitor chip
fuel, check injectors, o-rings
Mine sounds like a subaru too but I need a couple new coilpacks :P
flip3d is offline   Reply With Quote
Old 04-13-2008, 01:45 PM   #13
Z33dori
Z33dori's Avatar
one of your coil pack wires is splitting and grounding its self out...
and is more than likely about to fire out........it happened to me once....and now i have another one going out.
Old 04-13-2008, 01:47 PM   #14
TanaMU
TanaMU will become famous soon enoughTanaMU will become famous soon enoughTanaMU will become famous soon enoughTanaMU will become famous soon enough
wtf is up with you capitalizing the first letter of every word?
TanaMU is offline   Reply With Quote
Old 04-13-2008, 01:49 PM   #15
tha240star
gotcha, im goin to check for spark right now, thanks everyone!
Old 04-13-2008, 01:50 PM   #16
tha240star
sorry i was on my pda phone and didnt realiz it
Old 04-13-2008, 01:52 PM   #17
tha240star
damn are u serious? i hope thats not whats happening
Old 04-13-2008, 01:56 PM   #18
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
try playing around with your injectors
same exact thing happened to mine. i just played with all the injectors for a lil while and it stopped completely.
DataXUnknown is offline   Reply With Quote
Old 04-15-2008, 07:09 PM   #19
tha240star
well i have narrowed down the problem a little bit but i still need help. the 4th cylinder is the problem
since i found out it was spark, i switched coilpack # 1 with coilpack # 4. the 4th cylinder still wasn't sparking.
any ideas anyone?
Old 04-15-2008, 07:17 PM   #20
dtc 360RT
dtc 360RT's Avatar
Location: You can tell how I walk, I ain't from around herr..Five6Duece, Kings Only
dtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfection
Send a message via AIM to dtc 360RT
you can get a noid light, check that injector is getting pulse. check that coil is getting power. have you removed that spark plug? see what it looks like..hell check compression on that cylinder while you're at it. try to eliminate spark, fuel, compression....it'll lead you in the right way. either electrical problem or worse.
DTCPerformance.com, Socal-Drift.com, Myspace.com/Dtcperformance
DTC 360RT Review
dtc 360RT is offline   Reply With Quote
Old 04-15-2008, 07:21 PM   #21
redline454
redline454 will become famous soon enoughredline454 will become famous soon enoughredline454 will become famous soon enoughredline454 will become famous soon enoughredline454 will become famous soon enough
coil packs...it happened to me
redline454 is offline   Reply With Quote
Old 04-15-2008, 07:22 PM   #22
tha240star
well i already found out that the 4th cylinder doesnt have spark, and i already switched out the coilpacks with one that i knew was good, and still no spark from that plug
Old 04-15-2008, 07:22 PM   #23
ncrk
ncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choices
Send a message via AIM to ncrk
i heard something about someones car sounding like a subaru, and it turned out to be a clogged fuel injector
i think
ncrk is offline   Reply With Quote
Old 04-15-2008, 07:26 PM   #24
tha240star
whats a noid light?
Old 04-15-2008, 07:43 PM   #25
sTalnOut
sTalnOut's Avatar
sTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nice
Send a message via AIM to sTalnOut
Originally Posted by tha240star View Post
whats a noid light?
Noid Lites are the fastest, easiest, most economical way to check electronic fuel injection signals(got that def. off goggle hehe). Did you check your spark plugs and how do they looked? check all your wires, and check your fan wiring as well. I had the same problem as you before 1 of my wire got tap wrong and it burnt 1 of my coils bad my car was running on like 2 cylinder. Well i hope that helps
sTalnOut is offline   Reply With Quote
Old 04-15-2008, 08:59 PM   #26
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
Hey since I wont give you a sensible answer to such a ghey question, I will reply with.....
WTF?
How do you determine sound by a car label?
I should of hit you with the rep stick!!!!
I honestly don't think you have really driven in a subaru.
BigVinnie is offline   Reply With Quote
Old 04-15-2008, 09:25 PM   #27
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
cause it's misfiring hahahaha
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 04-17-2008, 04:36 PM   #28
tha240star
WTF?
if u cant help, then shut the f*** up. everybody else knew what i was saying, and u wanna come and add ur 2cents. take ur negative attitude and ur 2cents to the bank, and buy a efing clue.
100% A$$CLOWN
Old 04-17-2008, 05:12 PM   #29
Driftapparel.com
Driftapparel.com's Avatar
Driftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura about
Sounds like I am going threw almost exactly the same problem but mine is cylinder 3! its pissing me off too! I am finding that when I boost I hear a click and then it happens (wrx). so I pull the plug and it has no gap, so its not firing. plus the plug is pitted up. freakin wierd. ppl say it could be a detonation problem and I am running to lean. I am running stock fuel pump at what I think is stock boost.
I pulled everything apart and found that the flap connected to the actuator would stick open every once in while from hitting the elbow (dump) pipe. The turbo and elbow are both stock. I have no idea if this has anything to do with it or not so if anyone has any ideas, please post em.
I am running a front mount with hks ssq as well. FYI
Thanks and hope this helps a bit
-Brett
Driftapparel.com is offline   Reply With Quote
Old 04-17-2008, 07:04 PM   #30
BigVinnie
BigVinnie's Avatar
100% A$
Bam hit you with the rep stick. Don't tell me to STFU with your 5th grade grammar!!!
Look dude! I'm Nissan for life, but Subaru's sound clean too, respect your competitor. Your misrepresenting and making this forum look GHEY!
