Old 04-18-2008, 10:51 AM   #1
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
quick question about ground to mafs
ok i actually think i found out what was wrong with my car. i have a weak ground coming from the ecu to the mafs. i bought a new one just in case. would it be ok if i were to just ground the wire that is suppose to be the ground on the mafs somewhere else or does the computer need to see a ground?
moses is offline   Reply With Quote
Old 04-19-2008, 12:49 AM   #2
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
U should ground the wire to the maf where its suppsoe to be. There should be three wires
Luvs2slide is offline   Reply With Quote
Old 04-19-2008, 02:13 AM   #3
moses
there is three wires but is it ok for me to ground the one im suppoes to ground to a different ground. is it ok the ecu doesnt see it?
Old 04-19-2008, 03:38 PM   #4
moses
how can i find where it is original ground, or does it actually just go straught to the ecu? how can i fix that?
Old 04-19-2008, 05:41 PM   #5
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
jim wolf has a good page explaining...cant link sorry on my phone
TougeLabs is offline   Reply With Quote
Old 04-19-2008, 08:15 PM   #6
moses
can you put that link up later, i cant find anything. thanks a lot. does anyone know how i can make the ground stronger or something coming from the ecu
Old 04-20-2008, 04:11 PM   #7
moses
is it ok to ground it where i want it or do i have to keep it on the ecu ground
Old 04-20-2008, 10:48 PM   #8
moses
can i just 3 way the regular ground to my own ground
Old 04-21-2008, 10:18 AM   #9
didderson
didderson's Avatar
didderson will become famous soon enoughdidderson will become famous soon enoughdidderson will become famous soon enoughdidderson will become famous soon enough
Send a message via AIM to didderson
I used to run my old KA with the MAF ground spliced and just hooked up to chassis ground. It ran better with that setup.
Make sure your ecu is also bolted in so that the casing for it is grounded.
didderson is offline   Reply With Quote
Old 04-21-2008, 05:21 PM   #10
moses
hey thanks a lot for that. i will do that ^
but i think i have another problem. when i was checking for voltage on my ecu i wasnt getting any to the ecu powers. only the ecu backup power. and know for some reason my fuel pump doesnt turn on. i poped the eng cont fuse earlier but i replaced it with one that is close to the same. it was off of a junkyard 240 but it looked a little different. is that the problem
Old 04-21-2008, 06:36 PM   #11
moses
damn. i just read some old articles and i think i fried my ecu. how can i be sure i fucked my ecu up? i still have backup power going to it and the eng cont fuse is still different, so i got to go to nissan and hopefully buy the fuse.
Old 04-22-2008, 10:30 AM   #12
moses
holy shit. 25 dollars from nissan for the fuse. does anyone have any spare fuses they would like to sell? i hope this fixes it.
Old 04-22-2008, 04:04 PM   #13
moses
the fuses checked out good. does anyone know where the ecu gets its main power from?
Old 04-22-2008, 09:06 PM   #14
moses
y is my ecu power wire not gettin any power or y is my fuel pump not priming
Old 04-22-2008, 09:11 PM   #15
johngriff
johngriff's Avatar
are the led lights on? does the ecu smell like burning hair?
[email protected]
Old 04-22-2008, 09:22 PM   #16
moses
my little red light is not on but i dont remember it being on. i just need to know why im getting backup power and not main power. is there a fuse it goes thru other than the eng cont.
Old 04-23-2008, 09:24 PM   #17
moses
does the ecu main power go thru any fuses. which should i check?
Old 04-24-2008, 10:52 AM   #18
moses
i need to know why my ecu is not getting power
Old 04-25-2008, 02:24 PM   #19
moses
i have power at both eng cont fuses under the hood but i dont have any at b/w wire in the grey plug. what does that mean
Old 04-25-2008, 06:33 PM   #20
moses
yeah my car started but runs crappy. what should i check to make sure everything is good. i think it runs crappy because someone tried to tune it with the mafs bad. is there a way i can reset the afc neo. its time to go drinkin. ill let u guys know whats up tomorrow. what should i check to be safe
Old 04-25-2008, 09:41 PM   #21
drkidd22
drkidd22 is an unknown quantity at this point
You saying your ECU is not getting power but then you say that your car started? How could that be?
drkidd22 is offline   Reply With Quote
Old 04-26-2008, 08:10 PM   #22
moses
i really dont know how it started. i guess now its getting power since i switched the egi and egi pump relays out.didnt see power when i initially swiched them but when i pluged in the ecu it ran. shitty though. it cant even idle anymore??
Old 04-26-2008, 08:49 PM   #23
moses
hey i just noticed something.i have a black/white wire connected to three other b/w wires just behind the big rubber grommet. is this normal and if it is where do they go to because i might of shorted out something else.
Old 04-27-2008, 08:53 AM   #24
moses
does anyone else have that setup and is it ok
Old 04-27-2008, 03:23 PM   #25
moses
its mafs, ecu power, and something in the iacv (i think). does anyone elses do this
Old 04-28-2008, 11:01 AM   #26
moses
ok i just did a test. i unpluged my mafs and afc neo and the car ran perfect 14.8. i plugged in the mafs and i ran rich. when all are plugged in the car cant idle. what does this mean. could it be i blew my iacv when i popped the c/b?
Old 04-28-2008, 12:31 PM   #27
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
it probably means that the afc and/or the mafs is wired improperly
louisdaboois is offline   Reply With Quote
Old 04-28-2008, 04:35 PM   #28
moses
i just checked and there both are wired good. the reason i think it is the iacv is because there is a b/w wire that connects the maf b/w, iacv b/w and the ecu power all in one. so when i shorted the mafs, i could have shorted the iacv since there is no fuse for it. and when i unplug the mafs my cars goes into limp mode and the iacv doesnt send a signal anyways. does this make sense.
Old 04-28-2008, 08:44 PM   #29
moses
can someone let me know if this makes sense
Old 04-29-2008, 04:00 PM   #30
moses
hey thanks a lot Z U L8R. youve really helped me out a lot. and to who ever said the mafs can be grounded to a chasis ground is wrong. the ecu sends different signals through the ground for the mafs so ground at all times is bad and i probably messed up another mafs
