Old 11-06-2001, 06:22 AM   #1
gh6o6
gh6o6 is an unknown quantity at this point
I have to do a tune up and i want to know what are some good parts to use? will using proformance wires/plugs/dist. cap help any what can i expect?
does anyone have any sugestions?
gh6o6 is offline   Reply With Quote
Old 11-06-2001, 08:03 AM   #2
chickenmanq
chickenmanq is an unknown quantity at this point
Always use the best you can afford.  The car gods will smile kindly on you.
chickenmanq is offline   Reply With Quote
Old 11-06-2001, 08:12 AM   #3
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
For maintenance work - nothing beats genuine OEM Nissan parts.  Those are the best performing for what you are doing.  Some like to buy fat wires, but unless you are heavily tuned, they are unlikely to help.  Some like fancy plugs - which never seem to matter on the dyno.  Dist cap/rotor - the only choices are Nissan or "other."
HippoSleek is offline   Reply With Quote
Old 11-06-2001, 08:35 AM   #4
Gold240se
Gold240se is an unknown quantity at this point
I've been recomended to stick with the stock plugs, unless my car had serious work done to it.  The cheepsest I could find my stock plugs for are about $10 a pop.  Their NGK, so they've got to good.  I replaced my stock wires with NGK as well, they don't give you any more hp, but the car deffinately runs smoother.  I also did an oil change at the same time so that too had something to do with the smoothness.  I say deffinately stay stock with the parts HippoSleek was refering to.
Gold240se is offline   Reply With Quote
Old 11-06-2001, 10:54 AM   #5
chickenmanq
Depends on what plugs come from Nissan.  The NGK is used to use were ok, but there was a considerable amount of better pull through 4000 to 4500 rpm when I switched to Bosch Platinum +4's.
