Old 04-30-2008, 04:53 PM   #1
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Pblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of light
Feedback Score: 48 reviews
Question overheating issue
My water temp is rising and i dont know why. I have a 93 coupe with a blacktop and some go gast stuff(about 240-250ish whp on an untuned ecu @7psi)
the car has as follows
S13 SR20det blacktop
Tub manifold with Metal gasket
GT2560R-466541-4 (GT28R) Dual Ball Bearing Turbo w/Internal WG
Alum adap's for the turbo
S15 oil return
Earls oil and coolant lines (with restritor)
upgraded exhaust elbo
3" down pipe
3" test cat
3" exhaust
oil catch can
new water pump
New gaskets
30x12x3 FMIC
HKS SSBOV (New Style)
WAL 255 fuel pump
Battery relocated to trunk
New Radiator with dual Mishimoto Fans
DIF fan contoller
Alum coolant tank
Brake Heat sheild...
All new hoses and Belts (gates)
Mobile 1 synthetic
Im not leaking coolant(anymore, loose radiator dran plug) my fans work fine and its not too hot out here. It does it in stop n go mostly.
If anyone has a clue please let me know. My radiator is is a new oem ka radiator. Is this possibly an issue ? A koyo is about 2-3 weeks away.
Thank you, desperate and confused.
Pblesh85 is offline   Reply With Quote
Old 04-30-2008, 04:57 PM   #2
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
check the water temp sensor could be bad.
Old 04-30-2008, 05:03 PM   #3
my S14
my S14 is an unknown quantity at this point
Send a message via AIM to my S14
thermostat issue thats what i would try first, if your thermostat is stuck open or sticky it would over heat at idle and stop and go. theres no real airflow and if its open the coolant it just circulating around and the fans are not doing their job, when your driving the air flow from the road helps cool everything down.
thermostats are quick easy and cheep. thats what i would start with for sure.
then again im not an srdet guy thats just my best guess
:hammer:
my S14 is offline   Reply With Quote
Old 05-01-2008, 10:14 PM   #4
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
I will check it this weekend and give an update, thanks.
Old 05-04-2008, 08:10 PM   #5
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Question I hate nissans ! ! !
Ok so I changed my thermostat(brandnew nismo) and after 2-3 min at idle my temp gauge is through the roof. Im not leaking anything, my fans work just fine. Then hoping its just waiting for coolant to cycle through the motor and go back to normal. I wait 2 hours and drive down the road nice and easy no stop n go and 2-3 min its through the roof again. Before I changed it my car would run for 30-40 min before the temp went up(slowly). Now it goes up alot faster. And when I pop the hood it does not feel extra hot or out of the norm.
What the hell is going on ? Anyone that has an idea please tell me. I dont think it the coolant sensor because it read stable for 30-40 min before it would start to go up. Has anyone delt with this before ?
Do you suffer from vaginal dryness...
Old 05-04-2008, 08:12 PM   #6
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Will an sr run fine with a new ka radiator ?
Old 05-04-2008, 08:17 PM   #7
Jadeskyline
Jadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choices
Send a message via AIM to Jadeskyline
i had a similar issue....tiny pinholes in my heater hoses u wont see them but they are there
Jadeskyline is offline   Reply With Quote
Old 05-04-2008, 08:20 PM   #8
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
So did you have fluid leaking ? How did you fix your prob ?
Old 05-04-2008, 08:39 PM   #9
SR2Zero
SR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really nice
Okay, various suggestions that may or may not help.... Just kinda thinking out loud..
Insufficient water pump possibly... Sucky coolant circulation..
Empty, flush, fill, bleed radiator.
Make sure there is no air is in the coolant system.... Err... Radiator cap is good to go...
All I got.
SR2Zero is offline   Reply With Quote
Old 05-04-2008, 08:47 PM   #10
Jadeskyline
no fluid leaking i sat in front of the car for 30 min and saw nothing went driving car heated up heard a loud hissing noise (because i kept driving stuck in rush hour traffic)....finally pulled over and popped my hood and heard that the hissing was coming from a few TINY (and i mean TINY) pinholes....i just switched out my heater hoses and called it a day....does ur car overheat at idle as well or just while driving?
Old 05-04-2008, 08:51 PM   #11
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Its a brandnew water pump(less than 1000 miles), it overheats at idle too.
Old 05-04-2008, 09:11 PM   #12
Sileighty_85
Sileighty_85's Avatar
i found an effective way to bleed my system
1. fill radiator full
2. turn on/open heater
3. go WOT (2nd gear) till 6K let off gas and let the engine brake
do that 2 or three times and that should purge you system of air.
4. check coolant level and refill
Ive done this everytime and has worked for me with out a problem.
No insult intended but gotta ask
are your fans pushing or pulling the air in the correct direction?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-05-2008, 06:20 PM   #13
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
yes my cooling system is set up correctly. I might still have air in there. Im going to try bleeding my system again.
Old 05-05-2008, 06:37 PM   #14
NISMO WARRIOR
NISMO WARRIOR's Avatar
NISMO WARRIOR is an unknown quantity at this point
I had the same problem on my Black top got it fixed wen i found out that the heater hoses wen u run a heater core wasnt tight enough...... I know little things turn into big ones.
NISMO WARRIOR is offline   Reply With Quote
Old 05-05-2008, 07:38 PM   #15
scooz14
scooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura about
test your radiator cap to make sure it holds pressure. if it does not, it will overheat.
scooz14 is offline   Reply With Quote
Old 05-05-2008, 08:23 PM   #16
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
I will check it out. Does an sr need a cap that holds more pressure than a ka ?
Old 05-06-2008, 07:39 PM   #17
hwd_ca
hwd_ca is an unknown quantity at this point
Just take out your Thermistat...That might work.
hwd_ca is offline   Reply With Quote
Old 05-06-2008, 07:56 PM   #18
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
I solved the problem for the most part. I had to bleed the cooling system. As soon as I can buy a new radiator I believe the problem will be compltely solved. Although I now have a new prob. The bleeder screw/bolt behind the crank angle sensor on the water neck it stripped. I believe is the water neck thats stripped and not the bolt.
Does anyone have an extra they can part with ?
Old 05-06-2008, 08:04 PM   #19
GSXRJJordan
GSXRJJordan's Avatar
you almost definitely have air in the system. There's a bleeder screw on the water neck, take it out, start the car, turn on the heater, and keep the radiator full of coolant while coolant gets pushed out of the bleeder. You'll see a bunch of bubbles at first, then it'll be a solid stream.
Then put the screw back in, but be careful, that coolant will be hot.
Edit: buy the S14 water neck from a Nissan dealer, or find a used S13 one for next to nothing.
Old 05-06-2008, 08:15 PM   #20
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Do you have a part # for the s14 one ? And thats what I did to bleed the system.
Old 05-06-2008, 08:22 PM   #21
WISH ONE
sometimes it helps to jack the front of the car up so the radiator is at the highest point, you can squeeze the upper hose in a pumping sort of manner, dont burn yourself and like every one else has said turn the heater to the highest setting possible.this helps.....
Old 05-06-2008, 08:39 PM   #22
Oo_Skyline_oO
Oo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud of
Send a message via AIM to Oo_Skyline_oO
I've never worked on SR, but I kno on KA's there are coolant bypass hoses under and in between the intake manifold. check if they leak, and are the fins bent on the radiator??? if you have electric fans, make sure they are pushing air in the direction of the motor, and if you have clutch fan, make sure that the fan clutch isnt too loose, or it will heat up on idle.
Oo_Skyline_oO is offline   Reply With Quote
Old 05-06-2008, 09:25 PM   #23
Sileighty_85
http://www.thenismoshop.com/ikorb.ph...product_id=354
後輪駆動車1番
1986 SR86 - 200ish
Old 05-07-2008, 07:14 AM   #24
mifesto
mifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nice
also try adding a bottle of waterwetter.... it helps break up the bubbles...
mifesto is offline   Reply With Quote
Old 05-07-2008, 09:38 AM   #25
WISH ONE
does you heater work well?????
Old 05-07-2008, 12:38 PM   #26
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Thanks for the help and the website. All of this should be completely solved as soon as my koyo and water outlet gets here.
