Old 05-01-2008, 11:28 AM   #31
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Originally Posted by turtl631 View Post
Why would you use two of them next to each other?
Rack in and out. They came in a pack of two, so I used them
Originally Posted by Wiisass View Post
Cody, you mean 5/8" statoseal? 5/8" = 15.875mm
I had actually got the 9/16 per a thread on F/A about powersteeing, and they worked for both. Maybe it was a fluke??
Old 05-01-2008, 11:53 AM   #32
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
Lol, fair enough. Got any pics? Did you add a cooler also?
turtl631 is offline   Reply With Quote
Old 05-01-2008, 12:33 PM   #33
the head
the head's Avatar
Additional informaiton
SARD FPR uses 1/8" BSPT for its fuel pressure gauge port
Old 05-02-2008, 08:11 AM   #34
codyace
codyace's Avatar
Trader Rating: (58)
What's the PCV thread (passenger side, redtop??)
Pics will be coming soon! Waiting on my manifold (external gate) and my Ecu (i had hooked my water injection up backwards and friend a diode, to that's repaired) to get back, to clean her all up nice.
I did run a cooler, mounted it on the drivers side (s14) atop the front frame rail. I used the two existing studs there (from the stock intake bracing iirc) and it fit perfectly (used a small permacool cooler with -6 lines)...painted it all semi black and used black a/n fittings...with the intake in there, I don't think people will ever even notice it hehe.
/thread jack.
Old 07-28-2008, 12:46 PM   #35
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Bumping for...
Originally Posted by yarou View Post
What's the size of these two sensors right here? My old HKS water temp sensor seems to be the same but still possibly different, after tightening the HKS sensor in there it left a few small shavings. It looks dead on though when I compare both the threads
And those water fittings, if I remember right, they're M12x1.25.
Can anyone confirm this? I'm wondering specifically about the thread pitch for the water temp sensor for the gauge. I read somewhere else that it's M10 x 1.0. I'm about to order some adapter fittings from McMaster-Carr and at ~$10/piece, I don't want to get the wrong ones.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 07-28-2008, 01:05 PM   #36
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Originally Posted by McRussellPants View Post
Block 14x.15
14x1.5
Here are my contributions
HKS standard wastegate: 1/8" BSPT
Block turbo drain port: 3/4 BSP (on RB, I assume SR is the same)
MELLO*SOS is offline   Reply With Quote
Old 07-28-2008, 01:31 PM   #37
drftmark
drftmark's Avatar
drftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura about
fuel rail cover allen/hex head bolts.
m8x1.5 they are cheap at lowes and are a lot easier to take off than those damn screws that strip all the time.
drftmark is offline   Reply With Quote
Old 07-28-2008, 01:41 PM   #38
SHIFT_*grind*
http://zilvia.net/f/tech-talk/190241...mp-sensor.html
Some say M12x1.25, some M10x1.0. I'm gonna whore this question around until it's confirmed
Old 07-28-2008, 01:48 PM   #39
s15specR
s15specR's Avatar
Trader Rating: (18)
s15specR is making a name for him/her selfs15specR is making a name for him/her self
Feedback Score: 18 reviews
I bought a 1/8th NPT Tap (ACE hardware < $10) and tapped near the fact. water temp sensor and the adapter for my oil pressure...both defi guages used the 1/8th NPT fitting.
s15specR is offline   Reply With Quote
Old 07-28-2008, 07:07 PM   #40
SHIFT_*grind*
I pulled the sensor when I got home from work today.
Water temp sensor for the gauge is M12 x 1.25.
