Old 05-02-2008, 07:04 PM   #1
sldbyuramg
sldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant future
rear lights
yes i have searched... nobody has quite the same problem unless i missed it...
when im driving at night with my lights on and i press the brake pedal my brake lights come on and then dim to almost nothing...then when i release the brake everything comes back on...to start they run really dim without pressing the brake so im kinda lost.
im assuming it was a bad ground but i checked all my grounds and my fuses and my relays... there has to be a ground im missing....does anyone have any ideas or know of a problem like this?
please be constructive
sldbyuramg is offline   Reply With Quote
Old 05-02-2008, 07:10 PM   #2
worangejuice
worangejuice's Avatar
worangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond repute
ummm.did you try replacing the bulbs? My tails were acting weird and then I just changed the bulns and BAM! no problems.
http://i13.photobucket.com/albums/a253/worangejuice/sig-3.jpg
worangejuice is offline   Reply With Quote
Old 05-02-2008, 07:15 PM   #3
TPS240sxS13
TPS240sxS13 is on the path to ruinTPS240sxS13 is on the path to ruin
could it be a bad connection to the lights themselfs
TPS240sxS13 is offline   Reply With Quote
Old 05-02-2008, 07:34 PM   #4
sldbyuramg
yeah i replaced all the bulbs...forgot to mention that...
maybe i should just get new tailights and start from there
Old 05-02-2008, 07:46 PM   #5
Sileighty_85
Sileighty_85's Avatar
go to autozone and have your Alternator Checked
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-02-2008, 10:19 PM   #6
makulit054
makulit054's Avatar
makulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of light
if all your lights are dim, including your dash lights, headlights and brake lights then yeah your alternator could be going. but if it's just your brake lights then it could be something more. have you cleaned the light bulg sockets, especially the contacts themselves. . I know mine had some corrosion. sometimes it would not make a good connection.
makulit054 is offline   Reply With Quote
Old 05-03-2008, 01:10 AM   #7
sldbyuramg
ill do the autozone thing and clean the connections...thanks alot for the input guys
Old 05-03-2008, 08:00 PM   #8
ericcastro
ericcastro's Avatar
I think it sounds like its a problem that is originating from the sending end, not the recieveing end. meaning it might be pedal and relay thing, not a tail light, bulb issue.
