Old 05-03-2008, 02:23 AM   #1
don_bagz
don_bagz's Avatar
don_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to behold
s14 need help with a scraping sound
hi guys.. well i just got my 240 the other day and it is stock. when i pulled in in my drive way the first time i backed it in and I heard a scraping sound so i pulled out and just parked straight on with an angle (thinking it was scraping). Today I noticed as i was parking on a slightly inclined road the scraping sound came up again.. So i thought to myself, there is no way the exhaust would scrape on a level ground. So i figured it must not be the exhause scraping..
Does anybody have any idea what it could be? Thinking it might be the transmission, but it doesnt always do it. I still have to figure out when it does it. i mean i know it only does it when im in reverse, but, i think if i start steering it will make that sound. it sounds like its coming from the rear side of the car. Any advice would help.. thanx
don_bagz is offline   Reply With Quote
Old 05-03-2008, 02:59 AM   #2
berz
berz's Avatar
berz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfection
wow thats funny?? may be rear brakes but this thread will get you flamed cuss u dont make sense
berz is offline   Reply With Quote
Old 05-03-2008, 07:23 AM   #3
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
I hope you have your flame suit on.
d-faction.com
Landers is offline   Reply With Quote
Old 05-03-2008, 08:09 AM   #4
womenbeshoppin
womenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfection
Send a message via AIM to womenbeshoppin
i think you blew your engine, time to go to the dealership.
womenbeshoppin is offline   Reply With Quote
Old 05-03-2008, 08:33 AM   #5
don_bagz
don_bagz's Avatar
well the rear brakes does need to be changed... and engine? i dont think i blew my engine. coz i just had it checked and there wasnt any problem..
Old 05-03-2008, 08:59 AM   #6
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
???? i ma so confused.if it only makes the noise when ur reversing. dont reverse.
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 05-03-2008, 09:19 AM   #7
don_bagz
don_bagz's Avatar
well yeah, right now thats what im doing.. i try to park somewhere where i dont have to reverse when im parking or leaving.. but it abviously isn't normal for the car to have that scraping sound. So i want to figure it out and get it taken care of before it becomes a bigger problem..
Old 05-03-2008, 10:54 AM   #8
Sileighty_85
Sileighty_85's Avatar
its a commons sound mine did it even after i install new rear calipiers (seized) still did it. but iafter I went 5 lug i dont think it does it anymore its not really a problem
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-03-2008, 11:06 AM   #9
YoungGun
YoungGun's Avatar
Mine does the same thing in reverse, don't worry about it.
YoungGun is offline   Reply With Quote
Old 05-03-2008, 12:29 PM   #10
don_bagz
don_bagz's Avatar
okay.. im glad to know it is not a big problem.. i still want to get rid of it tho... hopefully i can fix it..
Old 05-03-2008, 05:32 PM   #11
Agamemnon
Agamemnon's Avatar
Your rear brake pads are worn down to the metal backing. Replace them. I'm sure the scraping has ruined the rotor as well. Replace that too.
Old 05-03-2008, 10:07 PM   #12
cronux
cronux's Avatar
cronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to all
or, like what i discovered in my s14 right when i bought it, one of the brake pads in the rear was missing (yes, missing) (the one next to the piston) and it was just the piston pushing on the rotor. yea.... that was a mess.
cronux is offline   Reply With Quote
Old 05-04-2008, 12:20 AM   #13
don_bagz
don_bagz's Avatar
oh damn.. i hope this is not the case.. i dont want to buy another rotor.. craps!!!
Old 05-04-2008, 02:49 PM   #14
Agamemnon
Agamemnon's Avatar
It almost a sure thing that you'll have to replace the rotor. Dont wait on it either. I had to wait til payday fix mine. Unfortunatly before I could fix it, the pad popped out when I engaged the e-brake and I had to drive back to the garage grinding the piston to shreds. The piston eventually came loose while driving and everything went downhill from there. I had to replace the rotor, caliper, and pads.
Old 05-04-2008, 03:17 PM   #15
don_bagz
don_bagz's Avatar
okay.. thanx alot.. i will keep that in mind
Old 05-04-2008, 04:17 PM   #16
Sileighty_85
I dont think anything is wrong with your brakes if you pads were gone/low it would be making the scrape griding noise everytime you brake.
But you said it only happens in reverse, im sure its low speed in reverse when you slightly apply the brakes huh?
Its a common gremlin nosie in S-13's.
Check your brakes anyway but im sure everything is fine
後輪駆動車1番
1986 SR86 - 200ish
Old 05-04-2008, 08:37 PM   #17
don_bagz
don_bagz's Avatar
yeah.. this is what i thought too. if it was my brakes or what not. it should be constant. but its not, it only on reverse, and it doesnt even do it all the time. I tried to do it the other day so my friend could hear it, it wouldnt do it.. but today, it did it again.. but tommorow for sure my brake pads are gonna be replaced. hope that takes care of it...
Old 05-04-2008, 08:43 PM   #18
Future240
Future Moderator
Future240's Avatar
you could go to one of those car places that do 30-point inspections and see what turns up. may sound cheesy but a girl i used to know paid like 20 bucks for one, and found out why her car battery would die all the time
Old 05-05-2008, 02:11 AM   #19
don_bagz
don_bagz's Avatar
i did get that done.. infact it was the 100 point inspection.. the thing closest that i could think of is the brakes.. they said brakes are down to 3mm. so, unless thats where it is coming from then yeah. but other than that i'd be lost
Old 05-05-2008, 02:38 AM   #20
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
brakes... why dont u take the wheels off and inspect it your self....... 30 bucks a piece for new rotors roughly, and about 20-35 for the pads...DIY... its easy
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 05-05-2008, 08:54 AM   #21
don_bagz
don_bagz's Avatar
yeah.. im just waiting on my friend.. he has been busy, so he hasnt been to the shop.. he has the jack and everything.. hopefully i can get it done today..
Old 05-05-2008, 10:13 PM   #22
infinitexsound
use your stock jack from the car... do a wheel at a time.. and buy some cheap harbor freight tool set.. all u need is the typical 3/8 12mm 14mm 17mm and 19mm... and a ratchet and a hammer...
Old 05-05-2008, 10:18 PM   #23
illvialuver
illvialuver's Avatar
so your car makes this noise only when your parking? it might be something with the breaks. I dont know its kinda hard to nail down something as broad as that.
Old 05-06-2008, 03:36 PM   #24
don_bagz
don_bagz's Avatar
naw. not when parking.. but when on reverse.. but it doesnt do everytime. makes ir even harded for me to nail the problem.
