Old 05-05-2008, 11:22 AM   #1
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
Detonation?
So about a month ago I let a friend of mine drive my s14 (s13 sr20det w/ gt2871r w/ 740cc w/ bpu) while I sat in the passenger's seat. The car is on 20lbs of boost and runs 93 Octane all the time with enthalpy rom tune. AFR at WOT is 11.3-11.5:1 always. UP around 4500rpm - 5500rpm in 4rth gear in WOT we could hear a quiet little noise that resembled bb's hitting a metal shield or something, it sounded like detonation. After 5500rpm it would stop.
Timing is 15 deg.
Anyways, I lowered the boost dramatically to 15lbs and I still hear it. Could it in fact be something else?
My Knock sensor is in good working order and ecu throws no codes, so if it was knock, wouldn't the car have retarded timing if it really was knock that was loud enough to be heard by human ear? The car runs flawlessly regardless.
I am almost wanting to make want of those home testers you bolt to your block with headphones and tubing. Anyone have any advice on where to look, or absolutely know what this is, than let me know. Thanks!
opponheimer is offline   Reply With Quote
Old 05-05-2008, 11:25 AM   #2
just1pepsi
just1pepsi's Avatar
just1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfection
Send a message via MSN to just1pepsi
Could have been i guess.. may not have been bad enough for the KS to retard anything. (bad gas possibly) May be a good idea to check for any air leaks on the intake side of things.. and the exhaust for that matter.. sometimes exhaust leaks make a noise sort of like you describe.. they can be more of a ticking, but thats not set in stone.
just1pepsi is offline   Reply With Quote
Old 05-05-2008, 11:28 AM   #3
opponheimer
thats not a bad idea to check for exhaust leaks, i know exhaust leaks can cause crazy noises. good suggestion, edit, I felt around for leaks didn't find any
Old 05-05-2008, 12:15 PM   #4
steve shadows
steve shadows's Avatar
Does he have an electronic Boost Controller?
With a solenoid valve?
Click Click Click goes the valve...just a thought
Like Me on FaceBook !
Old 05-05-2008, 12:20 PM   #5
posdrift240
posdrift240's Avatar
posdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymore
how much boost are those solenoid valves good for? I have one also.
posdrift240 is offline   Reply With Quote
Old 05-05-2008, 04:39 PM   #6
steve shadows
I don't know, ive used avcrs north of 30 psi.
Old 05-05-2008, 08:58 PM   #7
opponheimer
This is my car we're talking about and no I have an adjustable actuator rod. Its not the machine gun solenoid noise.. Any quick way i can check its detonation 4 sure?
Old 05-06-2008, 01:57 PM   #8
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
with a boroscope, you can look inside your cylinder through your spark plug hole hehe
you might wanna stay at 14psi on pump and put some race gas in there when you're gonna run 20psi. my .02
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
