Old 05-12-2008, 09:19 PM   #1
SleepR 240sx
SleepR 240sx's Avatar
SleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond repute
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
Coolant from tranny?
Engine: s13 Blacktop sr20det
Okay so today when i got home from school I noticed my coolant reservoir was nearly dry. I poured some more in and filled it up and let it sit to see where it was leaking from. Well it looked at first like it was coming from the bottom radiator hose, but it wasn't. In fact none of the hoses had a leak. Jacked the car up and it was clearly obvious it was coming from a spot on the transmission right next to where the transmission bolts to the engine. So anyone know what's going on/had this problem before? My first thought was cracked block however I would have expected to find oil leaking as well. Only other guess is a busted freeze plug. Any ideas? All help would be appreciated.
This is zilvia. We aren't nice.
Quoted For Truth
Check out the coolest new thing: toddrickkkkk.blogspot.com
SleepR 240sx is offline   Reply With Quote
Old 05-12-2008, 09:21 PM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
wash the bottom of your car really good
then get under it with a flashlight while someone fills the reservoir
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 05-12-2008, 09:27 PM   #3
SleepR 240sx
Um, I know exactly where it's leaking...it's a problem on the internal side..somewhere in the engine coolant is leaking down into the transmission housing and leaking out there.
Quoted For Truth
Old 05-12-2008, 09:29 PM   #4
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
check your water line to the turbo. that happened to me but not as bad as yours. thats the only thing i can think of that runs behind the motor unless you still are keeping your heater core.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 05-12-2008, 09:30 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
On what engine? Ive seen S13 SRs leak at the turbo coolant line in the back and drip on tranny bell housing. Could be doing something similar (heater core lines). What engine and which side do you think its coming from?
CLICK HERE!!!
Old 05-12-2008, 09:38 PM   #6
SleepR 240sx
Well I need to take a picture of it so you can clearly see it, but it is not dripping onto the bellhousing it's literally coming out of the bellhousing. If you clean it off you can watch it come out again. It's coming from a tiny recessed area just after where the transmission and engine bolt up.
Quoted For Truth
Old 05-12-2008, 09:48 PM   #7
Dousan_PG
Dousan_PG's Avatar
then u got some serious problems
since no fluid goes the the transmissino
hahahhah
Aaron
Pink GodziRa
Old 05-12-2008, 09:51 PM   #8
SleepR 240sx
Yeah i'm aware of that unfortunately lol. Anyone ever heard of freeze plugs rusting out or busting for no reason? That's about all I've got on this besides cracked block.
Quoted For Truth
Old 05-12-2008, 09:53 PM   #9
Dousan_PG
Dousan_PG's Avatar
no
its from your coolant line probabaly dripping down
coolant if it was coming thru the trans would come w/ mor eoil then coolant.
its just dripping down your engine over the the trans.
i just dropped my transmission this weekend again.
theres no way you could be having coolant come from it, unless you filled it with coolant.
Aaron
Pink GodziRa
Old 05-12-2008, 09:55 PM   #10
murda-c
murda-c's Avatar
either it's a coolant line, or you cracked the block/have a corroded core plug.
but most likely is it's the coolant line, and it's running down in the seam between the block and the bellhousing.
Old 05-12-2008, 09:58 PM   #11
240love
240love's Avatar
240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection
when i had my rb... i had the same issue and it ended up being a coolant hose under the intake mani, it poured from there and would just leak down to where the tranny is making it seem like it was leaking from it. Then again its an sr not an rb.
240love is offline   Reply With Quote
Old 05-12-2008, 10:01 PM   #12
!Zar!
!Zar!'s Avatar
Check your heater hose.
chances are it's coming from that.
Dripping on to your tranny, and down it.
Old 05-12-2008, 10:12 PM   #13
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
2nd!!!
Old 05-12-2008, 10:19 PM   #14
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
heater hoses
turbo coolant line
freeze plug
Those are your 3 options, I SERIOUSLY doubt the block is cracked. You need to get a cooling system pressure tester and find the leak. Watching it drip will get you nowhere, with a pressure tester it will squirt, that is much easier to find.
Old 05-12-2008, 10:21 PM   #15
!Zar!
!Zar!'s Avatar
I made a girl squirt once.
Didn't need a coolant pressure tester either.
Old 05-12-2008, 10:24 PM   #16
racepar1
racepar1's Avatar
I knew it was gunna happen! LOL! That is a TOTALLY different cooling system though man! Actually it is more of a lubrication system!
Old 05-13-2008, 09:31 AM   #17
SleepR 240sx
Alright thanks for the help guys, I'll be looking at all my hoses thourougly today.
Quoted For Truth
Old 05-13-2008, 09:40 AM   #18
Boostedkouki
Boostedkouki's Avatar
Boostedkouki is making a name for him/her selfBoostedkouki is making a name for him/her self
Send a message via AIM to Boostedkouki
Sr20's have heater hose's right on top of the tranny it has to be one of those lines its gonna be a bitch to reach them.. Goodlucjk
Boostedkouki is offline   Reply With Quote
